NP435 question
Old Dec 9, 2005 | 11:28 AM
Broke_Okie's Avatar
Broke_Okie
NP435 question
I have a NP435 married to a Dana 21 transfer case in my 71 f100 4x4. I want to bolt up a NP205 to my NP435. I know the outputshaft on my NP435 is a 10 spline and to bolt up the NP205 I need a 31 spline output shaft.Is that the only thing to do besides the intermediate adapter that I need to change? Is there a company that sells the 31 spline output shaft so I can do the swap?
Old Dec 9, 2005 | 08:48 PM
thesprocket26's Avatar
thesprocket26
You might need a different length drive shaft.
Old Dec 10, 2005 | 06:57 AM
The SnoMan's Avatar
The SnoMan
Try Advanced Adaptors.
Old Dec 10, 2005 | 11:39 AM
rebocardo's Avatar
rebocardo
You have a 2WD NP435 in the F-100 with the Dana 21, if you want a married transfer case you need a NP435 from a 4x4 (think 1973-79 or F-250) to use with your bellhousing.
Old Dec 10, 2005 | 12:01 PM
Broke_Okie's Avatar
Broke_Okie
I should just be able to change tailshafts ,the 2wd and 4wd np435 only has the one diffrence its the splines in the tailshaft from the trans to the tcase.
