ATF question
Old Dec 8, 2005 | 11:04 PM
eltakko's Avatar
eltakko
Smile ATF question
What type of ATF fluid do I need for a 93 F150 4x4 auto?
Also, pretty serious leak from under the transmission. Probably just pan gasket or should I check other things?
Thanks!
Old Dec 8, 2005 | 11:12 PM
pfogle's Avatar
pfogle
Mercon/Dexrom III. Stay away from the mercon V.
Old Dec 9, 2005 | 03:16 PM
white 01's Avatar
white 01
You could also be leaking from the output shaft seal.
