need help...no start
Old Dec 8, 2005 | 07:43 PM
pgotcher's Avatar
pgotcher
need help
have problem my 74 f100 turns over and over but wont start replaced the coil ,wires ,plugs, fuel pump ,and filter, ignition modgule ,and ign. switch also checked the timing
Old Dec 8, 2005 | 07:52 PM
classicfordfreak's Avatar
classicfordfreak
Which motor does it have in it?
Old Dec 9, 2005 | 06:17 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome to Ford Truck Enthusiasts!
We are happy you have chosen the best source for Fords!
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
Old Dec 9, 2005 | 11:52 AM
Mike G's Avatar
Mike G
First off, welcome aboard!
Secondly, these motors only require three basics to run, air, fuel and spark... Are you getting a spark at the plugs when you crank the motor? When you operate the throttle linkage on the carb (with motor off), does it shoot gas into the manifold (you should see a quick steady stream)? How did you check the timing if it isn't running?
Answer these and we can go from there. --Mike
tcbofade
Sep 2, 2013 04:42 PM
billb2000
1947 and Older Ford Trucks
Jul 18, 2012 08:30 AM
billb7984
May 28, 2004 06:58 AM
JEsterII
Bronco II
Mar 28, 2004 04:10 AM
