I just wired in a tach and I was wanting to know what wires (colors) coming out of the light switch run on the dimmer so I can run power to the tach light.
Thanks
Aaron
Same on my 71. Plug into it after it leaves the fuse. Mine leaves the headlight switch, goes down to the fuse box, comes back up into a big bundle, then over to the big plug for the instument cluster. I plugged my tach in right there.
