remove door panell
Old Dec 8, 2005 | 02:49 PM
JF5speed's Avatar
JF5speed
remove door panell
anyone have some tips on removing the door panell on a 96 explorer??
thanks
Old Dec 8, 2005 | 04:44 PM
mab6680's Avatar
mab6680
remove the two screws under the inside handle pull out the plastic plate that the two screws held in start at the bottom of the door and pull on the panell you may need to use something to get your fingers under it like a screw driver you will here the panell pins pop out now work your way around the panell till all the pin have pop now lift the panell up and out of the window channel unplug the connecters on the switch and its off if you have roll up windows remove window crank first
Old Dec 8, 2005 | 05:30 PM
JF5speed's Avatar
JF5speed
thanks!!!!!
