need help fast
Old Dec 8, 2005 | 10:59 AM
kenwoods77's Avatar
kenwoods77
Unhappy need help fast
hi im new to this forum. i have a 1977 f150 2x4 and im having some tranny problems. i recently changed the trans fluid and filter because it was shifting alittle rough, and it solved the problem, this mornin i go and start my truck, let it warm up, and it wont go foward. i also looked at the trany fluid and it smelled burned..... its an auto trans, c-6 and its got a 351 m. the thing is it will go into reverse fine, i need some help soon cuz im a student and its the only mode of transportation i have....i dont really have much money so i dont know about a new tranny, plus the truck isnt worth puttin a new one in....i need to know if there is something i can do or should i just work my a$$ off and try to find another junker or somthing. i need somekind of transportation but im also going to be starting boot camp in march (MARINES) so i dont need to find something fancy. IF ANYONE HAS AN IDEA OF WHAT I CAN DO PLEASE LET ME KNOW.
Old Dec 8, 2005 | 11:45 AM
bigredtruckmi's Avatar
bigredtruckmi
Veteran: Navy
It smelled burned and was it a very dark color. If it was then more than likely the clutch pack went out and will have to be rebuildt. Any tranny guys on line??
Good luck with the Marines. Start running and going pushups now to prepare for long days.
Old Dec 8, 2005 | 12:10 PM
wick246's Avatar
wick246
You might do a search in the clutch/transmission/drivetrain section for others who had similar problems. You should be able to find a usable C6 to replace it with for not much money if you look around. If it were 4wd I have one sitting in my driveway you could just have...
Old Dec 8, 2005 | 12:15 PM
Mil1ion's Avatar
Mil1ion
Welcome to FTE!
Read post number 1 Fast
https://www.ford-trucks.com/forums/s...d.php?t=102632
Then maybe check out the transmission (Drivetrain) Forum
Old Dec 8, 2005 | 12:44 PM
kenwoods77's Avatar
kenwoods77
thanx for the help....if anyone else has some input please do so......thanx bigred, i have beengetting ready for boot camp since september, cant wait to go in.
