Dash light problem
Old Dec 8, 2005 | 10:44 AM
Mike052's Avatar
Mike052
Dash light problem
I have a 1988 F150 XLT Lariat. The dash lights will not come on at all. I have swapped it for two different dashes and still nothing. The harnesses look good, and the fuse is good. Any ideas?
Old Dec 9, 2005 | 06:37 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome to Ford Truck Enthusiasts!
Stick around someone will be by shortly to answer your question.
We are happy you have chosen the best source for Fords!
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
Old Dec 9, 2005 | 09:14 AM
RogerFord1's Avatar
RogerFord1
i had the same problem with my 88 it was the headlight switch hope this helps
Old Dec 9, 2005 | 09:26 AM
RogerFord1's Avatar
RogerFord1
dash problem
we also have a 87 that did the same thing itfinally shorted all lights but headlights out
Old Dec 9, 2005 | 11:39 AM
ws595's Avatar
ws595
I second Roger's opinion. Replace the switch.
-R.
Old Dec 9, 2005 | 01:53 PM
Mike052's Avatar
Mike052
Thanks. Will try it this weekend and let you know how it turns out!
Old Dec 12, 2005 | 03:57 PM
gravydude's Avatar
gravydude
Samething for me as well. Make sure you replace the connector too. You'll problaby see it burnt up as mine did. This will be my second time doing the same job over again on my 89. You'll also probably smell it too.
Old Dec 13, 2005 | 03:36 PM
Mike052's Avatar
Mike052
Could this also be the reason my white reverse lights are constantly on as well?
Old Dec 13, 2005 | 04:00 PM
gravydude's Avatar
gravydude
Reverse lights should be on a different circuit. But who knows. The light switch is usually just a bad connection with the spring. (the spring is part of the varable resistance) Take the switch bracket off and poke around the spring connection. The shop manual will also show you where to check for resistance change is for the headlight switch. The reverse lights, I would think that is from the output sensor on the side of the transmission. If you take that sensor off, it should have a ball looking thing on the back of it. That may be stuck in.
