help with a 400
Old Dec 7, 2005 | 08:07 PM
7FORD2's Avatar
7FORD2
Question help with a 400
ok fellas i want to build a 400 with considerable hp so i can blow the chebbies away but it is for a 4x4 so i want gobs of low end torque it is gonna be done on a budget so if you guys would just give your opinions i would appreciate it thanks
Dustin
Old Dec 7, 2005 | 08:22 PM
81broncoguy's Avatar
81broncoguy
Smile A 400 with loads of torque and HP
I have a 400 with a .51/.51 crane cam, edlebrock 400 performer intake, holley 650CFM carb which is all the carb you need, re-decked heads, and the block is bored .30 over. I run a T-18 borg-warner tranny, but a C-6 will work just fine, depending on your tire size make sure you have the right gearing in your pumkins or you risk tearing up your planetary gear on a C-6. If you have any more questions, let me know. P.S. I would go with hedman headers, they work great for me.
