2000 f-350 psd problem
Old Dec 7, 2005 | 07:53 PM
elkarcher's Avatar
elkarcher
I have been noticing a problem with my truck for the past little while. It doesnt happen all the time but occasionally, after I shift, release the clutch and hit the gas, my truck stutters for a while until I accelerate and then the stuttering stops. It only happens when I am already moving pretty good like 3rd to 4th gears and up. I recently changed my fuel fillter thinking it might be that( needed it anyway) but no change. My check engine light is not on either.
Can you pick up any codes without a check engine light on? Anyone have any ideas? Thanks, I hope this makes sense to someone.
Old Dec 7, 2005 | 07:57 PM
1997F-350's Avatar
1997F-350
not every code sets a light.
try unplugging your icp sensor. if it runs smoother, there is your problem. buy a new one on ebay around 60 bucks. (btw with the sensor unplugged your check engine light will come on)
Old Dec 7, 2005 | 08:00 PM
hubdeep's Avatar
hubdeep
Sounds like it's a clutch, dose it seem to slip under load?
Old Dec 7, 2005 | 08:07 PM
elkarcher's Avatar
elkarcher
I havent noticed my clutch slipping at all. It kind of feels like it is not getting fuel or something. Thats why i tried changing the filter.
Old Dec 7, 2005 | 08:09 PM
elkarcher's Avatar
elkarcher
This may be a dumb question, but what and where is the icp sensor?
Old Dec 7, 2005 | 08:19 PM
PowerstrokeJunkie's Avatar
PowerstrokeJunkie
search feature works great. found this in under a minute. nevermind the writing, it came from kwikkordead's gallery and he was showing someone how to do the 10k mod.
Old Dec 7, 2005 | 08:55 PM
elkarcher's Avatar
elkarcher
Hey, thanks for the help. I will try that when it is warm enough outside to use my fingers.
