High Idle
Old Jan 22, 2002 | 07:41 AM
79fordslug's Avatar
79fordslug
High Idle
My truck starts fine and runs fine, but after the engine has warmed up and I put it in park to turn the engine off, it revs up to 2000 rpm. I am thinking there is a hot idle screw or something, but I haven't messed with the carb before so I don't know where it is. Any advice?
Old Jan 22, 2002 | 08:09 AM
William's Avatar
William
High Idle
Cold engine! Remove the air cleaner and spray choke cleaner on the carb linkage. Make sure every thing works easily, then use a little 3in1 oil on the moving parts. Just for grins, check the motor mounts.
William in Atlanta
Old Jan 22, 2002 | 01:09 PM
79fordslug's Avatar
79fordslug
High Idle
I checked the butterfly and sprayed it generously with gum-out as well as spraying the butterfly linkage. It seems that it is a little sticky and the trouble appears to be coming from the electic choke on the left side of the carb where the butterfly linkage attaches. Can I replace the electric choke easilly, or will the carb have to come off? Thanks for any help.
Old Jan 22, 2002 | 03:21 PM
77sc's Avatar
77sc
High Idle
LARIAT 85
Nov 3, 2011 05:32 PM
cajunsuperduty
Oct 28, 2011 03:31 PM
nosebreaker
Mar 29, 2011 08:09 PM
hornsurgeon
1997 - 2003 F150
Dec 19, 2010 12:17 AM
danm
Feb 14, 2000 09:08 PM
