jet size
Old Dec 7, 2005 | 11:25 AM
olered53's Avatar
olered53
jet size
i have a new 4mths. old 750 holley vac. sec. carburator what is the usual jet sizes that they come with,i dont want to mess the gaskets up or i would look i need some idea.
Old Dec 7, 2005 | 11:31 AM
The SnoMan's Avatar
The SnoMan
Jet size can vary with application but if you are running a 750 on a small (351 or less) V8, you are over carbed and you will have trouble with getting good responce for it and good WOT performance below 3000 RPM or so too. Better is raely better with a carb because you need to maintain airflow velocity rates in the throttle bores in a certain range for best performance
Old Dec 7, 2005 | 12:16 PM
Icicle's Avatar
Icicle
I cant help you, Im not a holley guy sorry
A 351? a 750 is actually too big for a 460 if its not built or turning high RPM's
