high rev when driving
Old Dec 7, 2005 | 11:07 AM
estrenge's Avatar
estrenge
I did a quick search and didn't find an answer.
My '81 f250 351 automatic revs high when is starts as usual and then idles down when I tap on the gas. When I'm driving around town it will run at a high rpm and won't come done much if I tap on the gas again.
Any ideas?
thanks, Eric
Old Dec 7, 2005 | 02:37 PM
Kemicalburns's Avatar
Kemicalburns
rebuild your carb and check for vacum leaks
Old Dec 8, 2005 | 10:51 AM
estrenge's Avatar
estrenge
Wouldn't a vacuum leak do the opposite and cause the rpms to drop and kill the engine?
What specifically in the carb would need to be fixed/adjusted?
Old Dec 8, 2005 | 12:24 PM
Kemicalburns
vacum leaks allow more air in and in which cause will lean out the motor and make it run at a higher idle. to much of course could cause it to die to.
the rebuild kits are cheap and have everything you may need like powervalve,gaskets and a new float. also clean it real good with carb cleaner its possible the butterflys are sticking open to
Old Dec 8, 2005 | 01:02 PM
fearfactory's Avatar
fearfactory
Yea a vaccum leak will cause high idle.I had a vacuum leak on my truck a few years back and it idled at 2k
Old Dec 13, 2005 | 09:40 AM
estrenge's Avatar
estrenge
Is there an easy way to check for vacuum leaks, or do I have to replace all the hoses?
Old Dec 13, 2005 | 09:59 AM
Kemicalburns
if you spray the lines with quickstart the idle will increase and you can locate the leak. if your motor has the hard vac lines figure to just start replacing them because they get brittle and dont last. regular rubber vac lines will work just fine. replace one at a time though so they get hooked up correctly. its not so bad once you get started honest
Old Dec 13, 2005 | 11:16 AM
estrenge's Avatar
estrenge
By 'quickstart' do you mean starter fluid? I'm new at working on engines.
thanks for you help too, by the way.
Old Dec 13, 2005 | 04:45 PM
Kemicalburns
ya, its used to spray into the air cleaner to help start equipment etc..
busflyer
Feb 13, 2015 09:59 PM
89FORD04
May 1, 2012 06:27 PM
86scotty
Modular V8 (4.6L, 5.4L)
Nov 8, 2011 05:27 AM
BearFootCustom
Feb 18, 2011 12:45 PM
6t6merc
Electrical Systems/Wiring
Jun 27, 2004 09:30 AM
