Bed weight for traction?
I have a 2000 F-150 4x4, and I used to add about 300 lbs of tube sand (back when I lived up north). I built a little rack to keep the bags of sand centered over the rear axle. You are correct in that your 4x4 can usually get you out of whatever you get stuck in, but the goal is to not get stuck in the first place
And as you said, its a pain to drive around in 4 wheel drive all the time, not to mention that fact that its very hard on the the truck. Just my $.02...
$140.00 is a little steep. Maybe if they were half price it would be a perfect thing to buy. However, I bet it would not fly through your back window if in an accident. Looks like a good product.
We usually don't have too much ice here in east TN and I haven't seen any for the two years I've had this truck so, I was just wondering how it would act. It is a 4X4 and I'm VERY familiar how much that helps on pure ice (yeah, not at all!) so, if I see snow acomin', in goes the sand, if it's ice....I'm stayin' home! ;-)
Sonny
The best winter driving suggestion I've read here is to get a set of Winter-specific tires and if that's not enough (I run winter tires here in MICH without any weight) then go for the loaded spare tire secured beneath the bed, as RACSAN suggested a fews posts ago. Sure a second set of tires isn't cheap, but then neither is body shop repair work after you can't stop or turn on a snowy road!
Regardless of the type or amount of weight you add, MAKE SURE IT'S SECURED! UNSECURED WEIGHT WILL TURN INTO A MISSLE AND SMASH THE FRONT OF YOUR BOX OR COME THROUGH YOUR REAR WINDOW if you ever hit someone/something or hit the ditch at more than 20 mph! I've seen it happen to two different friends of mine. I have one friend who had a floor jack in the trunk of his car (unsecured), and when he hit the ditch to avoid a large dog, the jack hit the back of the fold-down rear seat, pushing it down then traveled through the passenger area & out the windshield - just missing his head!
Good Luck & be safe!
BarnieTrk
Before I made the trek up to Ohio, I put new Goodyear Wrangler Silent Armour tires on my 2wd Ranger. Just before the snow started here I put 3 of the 60 lb. bags of tube sand (from HD) in my truck. Seemed to be a good amount of weight but once the snow started I would spin a bit on take off on slushy roads.
So, I added a 4th bag of tube sand and currently have 2 40 lb. bags of Driveway Melt (for my apt. sidewalk, etc.) which I will take out soon. I added a simple 2" x 4" frame to keep the weight centered above my wheels since the bags did slide forward on my bed liner and the Ranger was sagging w/ all the weight just inside the tailgate.
No problems w/ driving traction w/ the above mentioned amount but we haven't had any real icing yet, that may be the test. My mileage is down a bit but I am primarily driving on city streets, no highway cruises.
I personally like the idea of the sand filled spare but am not planning to be here beyond next summer.
Good luck.
sand wedged up front between a 2x6 and the cab. seems to help with
front end tires steering and brakeing. also have a large plastic toolbox
wedged between rear 2x6 and tailgate. nothing has slid around yet.
seems to help center of gravity, also didn't have to re-aim headlights!
Dave
I played the weight game - load in some concrete blocks, then tried firewood blocks, then bags of sand, etc. resulting in a lose of noticable steering response, some gas mileage, some use of the box because of the "constant cargo" in the back, etc. --- not good.
Winter tires are not designed to be run in temps >50*F, because they'll wear out faster, due to their very soft rubber compound and tread design. But if you can swing it, get a set of inexpensive steel rims from the junkyard or your local tire store and get a set of Winter-specific tires mounted up. You'll be spoiled forever more!!
Here in Mid-Michigan, I switch out my All-Terrian tires to my Winter tires the first week of November and switch them back again the last week of March. My last set of Winter tires lasted me 7 years....
Regarding driving on ice,,,,,,,,,, the Winter-specific tires help, but the only real choices for CONTROLLED DRIVING on ice are chains or studs; neither are legal in Michigan (unless you deliver USMail, Police, or such). If I'm faced with traveling on ice-covered roads - I'm looking to stay off those roads. Because even if I could stop, most of the other drivers won't be able to and end up hitting me! I'll choose to miss a day of work instead - because I don't make enough $$ in a day to pay for the parts & repair if I was to (likely) get hit or hit something due to the icy road days. As Dirty Harry said, "Do ya feel LUCKY??" Just my 2 cents,,,,,,,, I'll shut up now.
Good Luck!
BarnieTrk
