Engine Cuts Out Under Heavy Load
Old Dec 7, 2005 | 09:05 AM
burkie's Avatar
burkie
In the last 6 months, this problem just started. Pulling my horse trailer (about 13000lbs) up a pretty good hill, the engine misses momentarily and there is also a scraping noise. This is usually around 45 mph/2400rpm. I have the auto transmission. Once I get back to 60mph in overdrive everything is fine. A friend has the same truck (F350 DRW) and the same problem. His truck is an 03 mine is an 04. My truck has 30000 miles on it. I want to get it to my dealer if this is something the warranty will cover. Anybody else have this happen?
Old Dec 9, 2005 | 08:14 AM
huntercgr's Avatar
huntercgr
Does this noise sound like it's coming from the serpentine belt area? Mine does it too, and a few have said it was the fan clutch. Just asked my tech and he said it shouldn't make that scraping sound. Now to find a hill that I can duplicate it for him.
Old Dec 9, 2005 | 12:47 PM
chaddy's Avatar
chaddy
Mine was doing that...they changed the turbo charger...doesnt do itnow
Old Dec 9, 2005 | 01:32 PM
Hayapower!'s Avatar
Hayapower!
Same thing here, in one of fleet trucks..Same symtoms.. Turbo and EGR were replaced..
.........HP......
Old Dec 9, 2005 | 05:15 PM
JReinert's Avatar
JReinert
same thing also, when pulling a steady 20 to 25 psi boost the boost guage would drop 5psi and jump back up. The noise i hear is excess boost blowing back thru turbo. It did this with a chip in it but havn't seen since removing. I hope my turbo isn't going out!!
Old Dec 11, 2005 | 12:02 AM
cadyman's Avatar
cadyman
Mine was doing this also. Found some info on here saying that the EGR valve could be bad. I unplugged it and the problem was gone indicating a bad EGR valve. Dealer replaced it and no trouble since.
Joe
Old Dec 11, 2005 | 04:41 AM
BigF350's Avatar
BigF350
FTE Leadership Emeritus
FTE Emeritus
Welcome to the site cadyman!!!
Old Dec 11, 2005 | 01:50 PM
solman's Avatar
solman
bad miss
mine is doing same thing. It does it around 2000 rpm and will miss until i floor it. The black smoke rolls out so bad you cant see behind you. The dealership mechanic says bad injector. mine has 40,000
Old Dec 11, 2005 | 04:02 PM
huntercgr's Avatar
huntercgr
solman, your also makes a scraping/grinding noise? Mine doesn't spew black smoke, and I also had an injector replaced on day 2 with no sound. I find it hard to believe a bad egr would make something cause this scraping/grinding noise. But I don't know squat, so....... It would make sense that by punching it the sound goes away if it is the egr.
Old Dec 11, 2005 | 07:48 PM
cadyman's Avatar
cadyman
Mine would also go away when it downshifted. It is really easy to unplug it and go drive it to see if that is what it is. If it is, then take it to the dealer and tell them. That will give them somewhere to start diagnosing it.
Joe
Old Dec 11, 2005 | 11:03 PM
solman's Avatar
solman
mine doesnt make a grinding noise,but it pops and spits until i floor it and then it hesitates before it will take off. when it first started doing this while towing only .then started empty and got worse. I use my truck every day for pulling euip so its hard for me to take it to the dealer unless it just wont pull. its bad to say but it looks like i am going to have to buy a backup for my 40,000 dollar new one
Old Dec 12, 2005 | 07:50 PM
burkie's Avatar
burkie
Hey guys, thanks for your help. I'm going to talk with the service manager where I bought it. I'm glad I have something to go on. If this is serious I want to get it taken care of otherwise I can live with it.
p.s. this is still an awesome truck
Old Dec 13, 2005 | 08:43 PM
huntercgr's Avatar
huntercgr
I just may have to do some heavy 4 wheelin and see if my EGR comes loose.
Then see if I can replicate it. It also seems like we may have 2-3 different symptons, so this will be interesting.
