is 400 a small block?
Old Dec 6, 2005 | 11:14 PM
led129's Avatar
led129
is the 400 a small block, and is it a chevy?
Old Dec 6, 2005 | 11:16 PM
ford390gashog's Avatar
ford390gashog
not sure i understand at all. the 400 is a ford engine but is part of the 335 series. ford NEVER used the chevy term small and big block. chevy also had a 400.
Old Dec 6, 2005 | 11:19 PM
led129's Avatar
led129
well then... i umm... do you know what its closer too small or big block?
Old Dec 6, 2005 | 11:28 PM
ford390gashog
it is closer to a small block
Old Dec 7, 2005 | 12:41 PM
led129's Avatar
led129
k thanks, was trying to figure it out cause wikopedia.com was saying it was but my dad was like no its not bla bla bla
Old Dec 7, 2005 | 01:03 PM
fellro86's Avatar
fellro86
best erm would be medium block or mid block, as it is bigger than the 351W by far, but smaller than a 460, as far as size goes, not just cubes. It would be like calling a 352 or 360 a small block, even though it has way more weight than any of the Windsor types.
Old Dec 7, 2005 | 01:26 PM
ford390gashog
but a 400 uses a 351m block
Old Dec 7, 2005 | 01:54 PM
BIG-COUNTRY's Avatar
BIG-COUNTRY
i thought that the 351m was considerd a big block.
Old Dec 7, 2005 | 01:58 PM
ARMORER's Avatar
ARMORER
I have always heard them referred to as a "mid-block" or big block. But never a small block. The 351m and 400 were a block all their own. So usually they are called a 351m or a "400 ford" and people know what you're talking about. Now a Chevy 400 is a small block.
Old Dec 7, 2005 | 02:52 PM
broncobob's Avatar
broncobob
Technically, I think the 351M used a 400 block. The 400 appeared earlier (I think 71) than the 351M (Mid 70s sometime). If I remember correctly, the 351M is basically a 400 with a 351W crank.
But from the transmission bellhousing side, the 400 (and 351M) use the same bolt pattern as the 429/460, not the 302/351W.
Old Dec 7, 2005 | 03:24 PM
fordborn's Avatar
fordborn
the 351m was actually a cut back 400 that was done in the gas price/emission days. All the manufacturer's were cutting the engines back then. But as far as a small block vs big block then Ford never really used that terminology.
Old Dec 7, 2005 | 03:56 PM
qman's Avatar
qman
My block on my Suburban's 454 is massive compared to a Chevy 350. I just figured that's what was meant by small/big block. That sucker "is" big.
Old Dec 7, 2005 | 04:03 PM
subford's Avatar
subford
For more information on the M block go here.
http://home.earthlink.net/%7Ebubbaf2...history01.html
Old Dec 7, 2005 | 06:38 PM
led129's Avatar
led129
holy crap look what i started!
Old Dec 7, 2005 | 06:51 PM
andym's Avatar
andym
That's because the terms big block and small block are chevy terms, not ford ones. They get used a lot here when referring to the bellhousing pattern, as there are two main ones (forget the FEs for a minute). The 400 and 351M share the bellhousing patterns with a 460, and they're usually called big blocks. But it doesn't have anything to do with the size of the block. That's why it's not a very good term. The 300, 289, 302, and 351W all use a smaller bellhousing pattern, and are usually called small blocks. Again, nothing to do with the size of the block itself.
