Cam Info:
Old Dec 6, 2005 | 08:52 PM
4starcstms's Avatar
4starcstms
Cam Info:
Okay Ive got to pull the 390 out of my 75, to add a Ranger Torque Splitter and rebuild my Np435 as well as clean/paint the engine. Id like something with a rougher idle, but w/o having to worry about changing rockers, springs, etc etc etc. Idea's?
Its a 390 with a .030 overbore
cast iron heads w/ a decent port/polish job
Hedman Long Tube Headers
Edelbrock Dual Plane intake,
770 CFM carb
Ive got a mallory distributor here but need to get the vac advance adjusted closer to the stock dist. the new one takes 7 in hg of vac. vs the oe of 1.5 to 2 in hg ...
thanks for the input!!
Scott & Monster Tigger
Old Dec 6, 2005 | 09:42 PM
rusty70f100's Avatar
rusty70f100
How much compression are you running? Too big of cam with low compression will turn the motor into a dog.
Old Dec 6, 2005 | 09:47 PM
4starcstms's Avatar
4starcstms
not excessive amt, 9.0:1 or so I can run some compression tests to verify
