Sponsored by: Real Truck
4x4 hubs????
Old Dec 6, 2005 | 06:17 PM
bigford8486's Avatar
bigford8486
Question 4x4 hubs????
can i leave my hubs locked in and drive at high speeds. or should i unlock them?
Old Dec 6, 2005 | 06:36 PM
Miescha's Avatar
Miescha
Based on what I've been told in the past by others on this site, leaving them locked in won't cause any problem with high speeds. You may notice some axle bind on tight turns with dry pavement (and I assume you will not be making any tight turns as HIGH speeds - at least not on purpose).
Even with the hubs locked, you still are not in 4-wheel drive until you engage the transfer case (via a shift lever in the cab, or the dash switch with ESOF). The front axle will turn though, and some say this causes additional wear and greater fuel usage. Once you engage the transfer case, you can still drive at high speed, but you will use more fuel (engine now has to turn the front axle also) and you will notice much greater axle bind on tight turns with dry pavement (and I think you can break things in this instance).
Hope this makes sense.
