Newbie from Washington
I have a 2005 F350 crew cab diesel and love it. My only gripe is that the electrically heated seats only have one heat - full blast ! Has anyone investigated replacing the seat heat switch with some type of variable heat switch (even a high/low would be better?
The local Ford dealer said they know of no solution to my question.
Regards,
Fred Hardy
If you get a minute check out the link here, it will help you to navigate around and understand this site.
https://www.ford-trucks.com/forums/s...d.php?t=300691
We are happy you have chosen the best source for Fords!
Must read if you own a 6.0
https://www.ford-trucks.com/forums/s...d.php?t=325000
Enjoy FTE and The State Chapters are located at the bottom of the main forum page.
JOIN CLUB FTE -SUPPORT THE FORUMS!
See you on the boards.
I don't know how the new models are wired in terms of the seat heaters but I'm in the process of wiring in the seat heaters I just installed from a 99 Explorer. I'm going to play around with it and see if I can get a rheostat wired in there to adjust the temp. I'll let you know what I find out in the next couple weeks here.
If you get a chance come and join us in the NW Chapter: https://www.ford-trucks.com/forums/f...splay.php?f=89
Where in Washington are you?
Like Ivan said, stop by the Northwest Chapter and introduce yourself.
