67 F-100 Camper Special, 352, 2bbl, 4spd, 3.50 rear end
Well, I finally did a mileage check on my pickup and I am getting 8.9 mpg. How does this compare with your truck? Mine is a daily driver with relatively short, in town runs. I don't have a very heavy foot but I do leave it idling for ten minutes or so on those cold Arizona mornings. The engine is timed correctly (a little advanced at 10 btdc) and it runs very well.
Years ago I had another 67 with a 300 6 cyl. As I recall, it got terrible mileage too. Anyhow, I'd drive this truck if it got 5 mpg but I wish I could do better than 9! Any thoughts?
jor
I don't know of anything that would make a big difference. Just make sure the engine is in tune and your air filter is clean. Like John posted, the dual exhaust will help a little. I'm guessing you know not to use low first gear for normal everyday driving. Man would I like to have some of those "cold Arizona mornings" ha ha.
Wider tires increase rolling resistance because of more rubber on the road. Taller tires just lower the numerical ratio of the drivetrain, making the engine spin slower rpm's for the same road speed.
Case in point: If you had a smaller car, say a 280Z or something, and put really wide tires on it, over a given race course, you would average higher times (bad) than if you used a more appropriate tire size. Too wide a tire for a given amount of power is a waste as a lot of power is used up by friction. F1 race cars use huge slicks because they run 800+ HP.
I seem to recall previous posts that suggested
electonic ignition would help.
Also, do headers help by less restrictive flow
of exhaust gasses? I've already done dual
exhausts; can I keep those intact when replacing
stock headers with more efficient ones?
