rear end swap
Old Dec 6, 2005 | 12:56 AM
Never Done's Avatar
Never Done
rear end swap
I blew the ring and pinion on my 93 f350 crewcab and was wondering if a sterling 10.25 rearend from a 99up would swap in without too many complications. I know the wheel bolt pattern is different, but wheel adapters would fix that. Just mostly wondering about u-joints and e-brake. the reason i want to do this is to get disc brakes. thanks, Joe
Old Dec 6, 2005 | 09:25 AM
turbocoupe5.0's Avatar
turbocoupe5.0
Well, my 87 has a 10.25, so that diff has been in use for a while. I would say your best bet, unless someone here has done it and can just say yes or no, would be to break out the tape measure.
Check the
1. distance between the wheel mounting surfaces (a little variation here would probably be ok)
2. distance between the spring perches (you could relocate the perches if necessary)
3. the width of the spring perches (you could swap perches if necessary)
4. U-Joint size (if different, you can get U-Joints with 2 different bearing cup sizes or have your drive shaft modified for the newer yoke)
If the perches line up and the width is close, I'd say it should be fairly easy. Otherwise, it would require some welding (professional welding, unless you trust yourself). Regardless, I don't see why it couldn't be done.
Other things to consider:
E-brake, how are the cables connected to the disc setup?
ABS sensor(s) My 87 has one sensor in the pumpkin. The newer models may have a sensor at each wheel.
ABS computer, will the rear disc brakes confuse it?
Master Cylinder & proportioning valve, will they support 4 wheel disc?
Old Dec 6, 2005 | 10:08 AM
The SnoMan's Avatar
The SnoMan
Check the spring pad spacing to make sure it has not changes and if not it will bolt in without mods.
Old Dec 6, 2005 | 11:15 AM
andym's Avatar
andym
I would also be concerned about the VSS that your truck has (had). I don't know if the newer trucks used the same sensor, put it in the same place, etc. If you lose it, you lose your speedometer, cruise control, rear ABS, and if you have E4OD, the ability to shift correctly.
Old Dec 6, 2005 | 11:29 PM
Never Done's Avatar
Never Done
Thanks for you input, My brother just came home with a 2002 f250 so i'll do some measuring and get back to you.
Old Dec 7, 2005 | 10:28 PM
fordraceboy's Avatar
fordraceboy
wheel spacers aren't very tough if you do alot of hauling.... most are aluminum, steel ones are better..JMO
