...Welcome to Ford Truck Enthusiasts!
Stick around someone will be by shortly to answer your question.
We are happy you have chosen the best source for Fords!
Enjoy FTE....and JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
You lookin to do a suspension lift or a body lift? You can get a couple of inches if you crank the torsion bars and put on some shackles and add-a-leafs. For a 3'' body lift you would need to get a Performance Accessories 883 kit for a '98 Ranger. The kit will come with everything except rear bumper brackets. You could also do a spindle lift for the front and a SOA on the back but that is the most expensive route.
a suspension lift its all most time for tires and i want to put some bigger tires on it just has some crap highway tires on it right now so any kit for a ranger well fit?
I raised my 98 4dr 1 1/4" to fit some 31/10.5/15s BFGs it looks and rides great. I used some Warrior shackles for the back and did a wheel alignment/torsion bar lift for the front. I cost me about 70bux for shackles and about the same for the W/alignment.
Take a look at my gallery if you like, she has the alcoas and bfgs off a ranger "level 2" off road package.
