Sponsored by: Real Truck
steering correction problem
Old Dec 5, 2005 | 05:23 PM
dieseled's Avatar
dieseled
Question steering correction problem
Hi, I am new at FTE and I have a problem that I am seeking help with.
I recently lifted my '99 F-350 Diesel 6" and got the alignment all done. After my alignment the truck was pulling to the left and I was told that it was as close as they could get it. I was told to bring the truck back after a couple of weeks to allow the lift conponents to settle so I did. The truck drives straight now the steering will not correct itself back to center after making a left or right turn. The alignment shop did notice the problem when the truck was done but didn't have any idea of what was causing the steering problem.
I hope to hear back with some suggestions on what to check before I spend more money trying out different ideas. Thanks.
Old Dec 5, 2005 | 05:28 PM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome to Ford Truck Enthusiasts!
Stick around someone will be by shortly to answer your question.
We are happy you have chosen the best source for Fords!
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
Old Dec 5, 2005 | 05:35 PM
dieseled's Avatar
dieseled
I am new at this so I hope not to get lost, I think I can handle it...
Old Dec 6, 2005 | 04:52 AM
SRD4X4's Avatar
SRD4X4
Best guess would be that they changed 1 or both of the camber/caster adjusters (on upper balljoint) and over tightened the nut.See it all the time.
Old Dec 6, 2005 | 06:14 AM
FortyFords's Avatar
FortyFords
Or your ball joints are going bad ,They sometimes stiffen up before they get loose.
Rich
