Where do you live Aaron? That would be my deciding factor. If its a cold climate place that regularly sees real cold temps in the winter I would go with the 50w or a synthetic gear oil. If you live in an area that rarely sees below freezing and its over 80 or 90 in the summer I would run the heaviest gear oil known to man! The Synthetics are the best in my opinion. They cover a wider temp range than any of the regular oils, even in the extreme climates.
