Brake Drum Question
Old Jan 26, 2002 | 02:24 PM
Wrecker's Avatar
Wrecker
Post Brake Drum Question
On a 1979 F250 with a Dana 60 rearend, Do the Brale Drums seperate from the Hubs, by removing the Wheel Stud bolts, simalar to the way The rotors seperate from the hubs on the front end, or are the hubs and drums all one piece?
Thanks in Advance
Wrecker
Old Jan 26, 2002 | 05:41 PM
rick_369's Avatar
rick_369
Brake Drum Question
Does your trucks axle bolt through the hub, or is your drum on the axle?
Old Jan 26, 2002 | 09:47 PM
Wrecker's Avatar
Wrecker
Brake Drum Question
>on the axle?
The Axle bolts through the hub. I have removed the bolts, removed the axle shafts, and taken the drums off the truck.
Old Jan 26, 2002 | 10:40 PM
Kenworth's Avatar
Kenworth
Brake Drum Question
The drums off of a Dana 60 hub like yours by punching the wheel studs out then the hub section should separate from the drum. Its a fairly simple job but when you put the assembly back together put new studs into the hubs. Its a real b!tch when you spin a stud because the splines that hold the stud into the hub lets go when tightening the wheels back on. Also make sure the mating surfaces are perfectly clean when puting the hub and drum back together, if its off a bit you will end up with viberation.
KW
Old Jan 27, 2002 | 07:39 PM
jowilker's Avatar
jowilker
Brake Drum Question
Old Jan 27, 2002 | 07:54 PM
Wrecker's Avatar
Wrecker
Brake Drum Question
>KW
Thanks.... I appreciiate it. That is just what I was looking for.....
PM
