Valve springs???
Old Dec 4, 2005 | 10:27 PM
ReGGaTarT's Avatar
ReGGaTarT
Valve springs???
I'm planing to build a 400 engine. I have a Comp 268H cam, roller rockers and I'm looking for valve springs to match.
Would the 4bbl cleveland springs be ok?
Or would it perform better with dual springs that handle 550lift like the Elgin # RVK-9901S?
Old Dec 4, 2005 | 11:37 PM
Torque1st's Avatar
Torque1st
Posting Legend
Call comp cams tech line for their recommendation.
Old Dec 4, 2005 | 11:50 PM
grclark351's Avatar
grclark351
i'd let the guy doing your heads get the right springs for you, he may have to work the spring seats and/or change the retainers for clearance due to the added lift of the cam. the 268H is a "done deal" in a Cleveland, but the M/400 heads are different. stock 4V springs should be OK if they check out pressure-wise but springs do crap out, they aren't an item that usually gets re-used from one engine to the next, unless they check out OK! what is the casting number on your heads? (year) 1975 and later M/400 heads are different in the exhaust port than 1974 and earlier.
Old Dec 5, 2005 | 12:35 AM
ReGGaTarT's Avatar
ReGGaTarT
I have Cleveland 2V heads from a 1969 Cougar and my 400cid block is in a 1977 LTD landau 2dr.
Old Dec 5, 2005 | 12:39 AM
grclark351's Avatar
grclark351
good times then. are you going to have the heads done by a shop?
Old Dec 5, 2005 | 12:42 AM
ReGGaTarT's Avatar
ReGGaTarT
yes but I'm still not sure of the work to be done.
Old Dec 5, 2005 | 12:49 AM
roushracing617's Avatar
roushracing617
I would take Torque1st's advice. Comp Cams made the cam, they know what it needs to work properly. Why guess when they already have the answer? Call them.
Old Dec 5, 2005 | 12:54 AM
ReGGaTarT's Avatar
ReGGaTarT
I will call comp cams as soon as I can.
When I'll have my heads to the shop I will ask for a multi angle valve job, I have 1.65/2.07Ferrea race valves.
Some people say to remove the little bumps in the exhaust ports and some other people say not to remove...
Old Jan 18, 2006 | 12:37 PM
ReGGaTarT's Avatar
ReGGaTarT
I called comp cams and they couldnt tell me if the 4bbl vlalve springs could match a 268H cam, I talked with an old man and he told me to use comp 940 springs or other springs with same pressure...
I will ask my parts guy to ship me 940-16 comp spings instead of 4bbl springs. I'm still waiting for the invoice... I buy a lot of my stuff from hd_mad_dog (Maddog racing and fastengineparts) on eBay.
1974xlt
Mar 18, 2017 12:03 PM
72CC428
Jun 28, 2016 02:02 PM
trozei
Jun 16, 2016 02:57 AM
djed
S. California Chapter
Aug 11, 2013 08:59 AM
1972FordCustom
Mar 19, 2006 10:59 AM
