Sponsored by: Real Truck
What goes here?
Old Dec 4, 2005 | 08:15 PM
johnw's Avatar
johnw
What goes here?
I have a 2005 f250 xl, not many options as the xl would suggest. I have an oval shaped hole cover about an inch tall on the left side of the dash, just to the right of the area where the headlight switch and panel light control is located. What goes here. I would like to install a spring return switch in this location, any suggestions? John
Old Dec 4, 2005 | 09:20 PM
Beast12's Avatar
Beast12
That is where the switch for the power adjustable pedals goes. You don't have them (obviously) so you should be able to use it for whatever.
-Matt
Old Dec 5, 2005 | 12:41 AM
justinthurn's Avatar
justinthurn
yep, just a blank cover on your truck, plenty of room to put a switch, you can even cut the dash to fit a larger switch if needed.
Old Dec 5, 2005 | 07:45 PM
johnw's Avatar
johnw
I like having the ford finish on the dash. How does the power adjustable pedal switch work? I am looking for a switch with two positions, both spring return to a middle position. It would be great if I could use the same switch. Thanks for the info. John
Old Dec 5, 2005 | 07:54 PM
gagnonconsulting's Avatar
gagnonconsulting
I think that the factory power pedal switch will be exactly what you want. It is center off and springs back to center on release. I think it would be best described as a single pole double through momentary, center off.
BTW, what are you thinking of using it for? Just curious.
schmidt64's Avatar
schmidt64
I'd think that the pedal switch would be a on/off/on momentary switch. Can anybody clarify?
Old Dec 5, 2005 | 08:47 PM
Beast12's Avatar
Beast12
It is. It springs back to the middle when you let go of it.
-Matt
Old Dec 6, 2005 | 07:33 PM
johnw's Avatar
johnw
Yes, that is exactly what I want: on / off / on spring return to center (off). I am planning to rig it up to lock and unlock the doors on my service body. Anybody happen to have a part number? John
Old Dec 6, 2005 | 11:27 PM
tvsjr's Avatar
tvsjr
John-
The Power Adjustable Pedals switch is On Momentary/Off/On Momentary. There's no locking On position.
Look at the Carling Technologies switches... I believe one of their rocker switches is available in an On/Off/On Momentary configuration.
whiteoak11
Aug 23, 2018 04:24 PM
cowboyjesus
Dec 17, 2013 05:35 PM
jowilker
2004 - 2008 F150
Feb 26, 2013 08:53 PM
johnw
Apr 10, 2006 06:58 AM
safer
Aug 19, 2000 10:05 PM
