1978 - 1996 Big Bronco
89 bronco help!!
Old Dec 4, 2005 | 07:45 PM
87wreckerman's Avatar
87wreckerman
89 bronco help!!
ok i just got a 89 bronco xlt and it has a western plow on it, the front shocks have air bags on them to help with the added weight, the airbags seem to be leaking is their anything i can spray in their to help the leak cause its not bad slow leak, if not are they costly to repair? can i just replace one of the gas shocks on each side with one air shock on eachwheel instead of the airbags to help keep the front end up? just not looking to dump alot of money in it right now but i do need to keep the front end up when plowing, figure the airshock is a cheap way.
thanks for any help!
Old Dec 4, 2005 | 10:22 PM
Bronco#3's Avatar
Bronco#3
I have a 90 bronc w/ a westen 7.5 plow, I installed coil springs from a 1990
F250 2 wh drive. Fit great and front end doesn't drop at all. Eady installation.
Got the idea from this thread:
https://www.ford-trucks.com/forums/s...d.php?t=350714
HTH.
Old Dec 5, 2005 | 03:13 AM
87wreckerman
yeah i think i mite check into that. does anyone lnow what kind of psi these airbags can hold?
