Transfer case bearings
Old Dec 4, 2005 | 11:39 AM
dybeepvw's Avatar
dybeepvw
95 Explorer XL 4wd, 5 speed, 118,000 miles. Had to have trasfer case bearings all replaced the other day. The rear shaft coming out of case you could shake it up and down, a lot play and it was leaking some fluid out also. We have hardly ever used the 4wd. and kept the fluid changed regularly. My mechanic went thru the whole case and ended up costing $1000 and warranty for a year. Just wanted to know if anyone else had this problem.
Old Dec 5, 2005 | 01:50 PM
aquanaut20's Avatar
aquanaut20
my 2cents, usually this bearing will fail it the shaft is not balanced or the U joint or slip joint is stiff/worn...
Old Dec 5, 2005 | 02:06 PM
dybeepvw's Avatar
dybeepvw
Ok aquanaut20 thanks for the information, good to know that. I now have u-joints with a grease fitting in them.
Old Dec 5, 2005 | 04:12 PM
aquanaut20's Avatar
aquanaut20
dybeepvw,
Thanks for the reply, always good to look for the source of the problem not just the results.
We have 2 Explorers 92 (350K) and 97 (310K) used for Rescue Dive unit, we drive them hard, so we keep them in #1 shape, have been good vehicles.
