Voltage Regulator system
Old Dec 4, 2005 | 09:48 AM
dtony's Avatar
dtony
Hi all,
Wading into new waters with this one. My 72 F100 and I went on a trip last night. When I got ready to head home the batter was dead. I got it jumped and it ran, but the lights seemed unusually bright. This morning it seems that the wires that go to/from the voltage reg have been cooked.
This is a very well used pickup and I don't think this is the original volatage reg system. It looks like one from a newer model. Despite that, it looks like a matter or replacing the burned stuff with new and replacing the VR (which I assume is what caused the wires to get too hot.
Can anyone tell me if putting this back together is something I can handle or should I send it out?
Thanks!!
Tony in New Mexico
Old Dec 4, 2005 | 11:01 AM
jor's Avatar
jor
You can probably take care of it yourself. If you need the wiring diagram, PM me with your email and I'll send it to you. It's probably just a matter of replacing the burnt wiring and the voltage regulator and making certain you don't have any bare spots.
jor
Old Dec 5, 2005 | 03:55 PM
1975Ford's Avatar
1975Ford
When replacing wires, make sure you verify which wires are fusable links and which wires are normal wires. I have a samples of fusable links in my gallery.
Solder all joint connections when replacing wires, and use electrical tape or heat shrink connector on solder joints.
