Sponsored by: Kumho
Torq-Thrust D's??
Old Dec 4, 2005 | 09:02 AM
FLgargoyle's Avatar
FLgargoyle
Torq-Thrust D's??
I really want American Racing Torq-Thrust D's for my '64, but I see they are not available in 5 on 5-1/2". Did they ever make them? I can find a rear end w/ a smaller pattern, but what about the front (rotors)? Can I re-drill and press in studs on a smaller pattern? It is a '76 front end, and I'm a toolmaker, so machining them wouldn't be a problem. Has anyone done this?
Old Dec 5, 2005 | 11:19 PM
hotrod48's Avatar
hotrod48
Read through this thread. It list the year ranges of axles you can use in your current 9 inch to get the smaller bolt pattern. https://www.ford-trucks.com/forums/s...d.php?t=127564
I redrilled the axles on my 48. It took a little work, but I will be doing that swap hopefully sometime this winter. Good luck.
hotrod48
