Sponsored by: Real Truck
rear axle work
Old Dec 3, 2005 | 08:44 PM
captchas's Avatar
captchas
Guest
rear axle work
i just got done doing a rear axle rebuild swap gallery for the super dutys.
we had some fun and did a 3 way swap and change, puting 513's into a 02 sc 5.4 with 42 inch tires. 456's from the 02 into my 05 and my 410's into a 02 psd.
tools needed but not talked about are a big hd 1/2 air gun,sockets of 3/4, 13/16, 1 and 1/8 for the pinion gear nut. a depth gage set, dail indicator set. 1/2 torqe wrench. inch pound torqe wrench of the T head type to check pinion preload and spin when crushing the new sleve. big hammers, some assorted brass punches, some heavy. bearing seperators to pull bearings off. and a 20 ton press near by.
took about 4 hours each on the rears and just over 5 per truck for the fronts due to esof front ends and two trucks with bad u-joints on the axles.
all i can say is what a difference in each truck, esp.the 5.4 with its 8 inch lift and super sized tires. the psd had 4 inches and so so large tires.
Old Dec 3, 2005 | 08:46 PM
ford390gashog's Avatar
ford390gashog
ok,
i think you have a LOT of extra time on your hands. lol.i wish i could tackle those jobs so easy.
Old Dec 3, 2005 | 08:48 PM
captchas's Avatar
captchas
Guest
it's called 41 years in dealer ships fixing them.
on edit i should add i'm also retired so it helped kill time.
Old Dec 3, 2005 | 08:49 PM
ford390gashog
nice work. looked at the pics. nice job. huge tires.
