about ford 400
Old Jan 20, 2002 | 10:35 AM
bleedfordblue's Avatar
bleedfordblue
about ford 400
i heard a 400 was a crappy motor because they are bad about blowing up. Is this true? if so, then why? im thinking of buying a 69 with a 400 and a c-6 but i need to know a little about it first.
Old Jan 20, 2002 | 10:45 AM
Nitro's Avatar
Nitro
about ford 400
Everyone has their own series of engines that they favor more than the other. Take jowilker and stockman around here they are all for the FE series engines, and Im kinda partial to a few out of every series so it depends on the person. A 400 is not really a "bad" engine as you put it. These engines can be made into a fire breathing bad ##### motor if you want but few people choose to do it because of the availability of parts is kinda low. They make great torque because of their long stroke and seem to last a long time from what I have seen. One downfall of them is the oiling process in them. The cam for some reason got fed much more oil than it needed and therefore kinda starved the mains which may be why you heard they are bad. Thats my opinion on it.
Nitro
Old Jan 20, 2002 | 10:56 AM
bleedfordblue
about ford 400
the cam in this truck collapsed... strange.....
Old Jan 20, 2002 | 11:19 AM
impact's Avatar
impact
about ford 400
I had a 400 in my 79 4wd.It had alot of miles on it and ran very good.One day on the way to work it broke a wrist pin and sent the rod thru the block.I have heard from others not to rebuild the upper end [cam,lifters ,timing chain] only because the bottom end will chunk a bearing.
Old Jan 20, 2002 | 01:40 PM
Mil1ion's Avatar
Mil1ion
about ford 400
The 400 in mine before I yanked it, had 418,000 KM on it.
It Wore out <>It Didn't Blow up.
Dennis
Oh....Please Don't Ask Me Any Tough Questions As:
"I'm Saving Up MY Memory For When I Develop Alzheimer's"
78 F-150 429CJ C6 ,Silver w/Explorer Pkge
641/2 Mustang,Pre-World's Fair Car #8092
64 Fairlane S/C waiting for a 390-4spd.
68-Mustang.Sunlit Gold 80,000 miles
Old Jan 20, 2002 | 02:23 PM
flyboy2610's Avatar
flyboy2610
about ford 400
I've had 2 vehicles with 400 Fords in them. Never had a problem with either one.
Old Jan 20, 2002 | 07:26 PM
BOSS302's Avatar
BOSS302
about ford 400
I was reading an artical on a web site about the 400 becouse I am going to rebuild one for my truck. Here is the web site: www.projectbronco.com
Has some good ideas and is a work in progress.
LWhite
Old Jan 28, 2002 | 01:48 PM
DavidB's Avatar
DavidB
about ford 400
I have had a couple of 400s. It would not be my first choice to use for building a hot rod because of high performance parts availability, but for a daily driver it is a good, strong, long lasting engine. Be sure that the "C6" is really a "C6". A lot of 400s came with "FMX" (cast iron case) transmissions behind them.
Old Jan 28, 2002 | 03:41 PM
ummduh's Avatar
ummduh
about ford 400
Never "blew up" one, did spin a rod (my fault, rod cap on backwards), and the original was on 7 cylinders, the pushrods got twisted upo and fell out of the # 7 cylinder, but i towed a full size chevy about 70 miles like that WOT in 2nd gear on the freeway. It had no oil pressure, but it never stopped going.
And now I just picked up a F250 with a strong stock 400 in it.
Old Jan 29, 2002 | 03:37 PM
dfisher1's Avatar
dfisher1
about ford 400
All,
If we are talking about the 400M I do not believe that motor is original in a 69 is it?
The 400 m is a stroked 351M which is a kissing cousin to the 351C. These motor have racing blood in them and I've seen them win endurance races at the track. Stock! I am a strong believer in modifying factory product to perform to my standards and this is the motor I would choose. I've got alot of experience at doing it and cannot guarantee you'll get what you want. But good luck if you do choose that route.
My Way is the Highway
KingFisher
Old Jan 29, 2002 | 06:13 PM
Mil1ion's Avatar
Mil1ion
about ford 400
Fish,
The 400 is just a *400*
the 351M is the only M engine.
The 400 doesn't have an M behind it.
I thought you knew that ?
Dennis
"I'm Saving My Memory For When I Develop Alzheimer's"
78 F-150 429CJ,Silver
w/Explorer Pkge.
641/2-Mustang 260,Pre-World's Fair Car.
64-Fairlane500 S/C waiting for a 390-4spd.
68-Mustang 289-Sunlit Gold 80,892Mi
78-Buick LeSabre 403 4V
84 Volvo DL Wagon
Old Jan 30, 2002 | 12:34 AM
THE FORD's Avatar
THE FORD
about ford 400
I own a 79 4x4 with a 400, I run it very very hard, runs like a champ, no problems, all stock
Old Jan 30, 2002 | 09:10 PM
I_Thnk_Ford's Avatar
I_Thnk_Ford
about ford 400
I bought a 78' 150 from a rancher. Got it running good. Oil pressure dropped to nothing after she heated up. Was told probally worn mains. Had a rear main leak to boot. Upon replacing the rear main seal. checked main bearings to find them worn out. Even though I was told " It won't last by just replacing the mains." I've gotten 5,000 out of her since and she still hold a constant 30-35 psi at idle. Sweet motor.
Old Jan 30, 2002 | 09:29 PM
Cowboy_351's Avatar
Cowboy_351
about ford 400
Both of them hold the M-block designation because the 400 and 351M share a common block. the reason for the M is to keep it seperate from the Windsors and Clevelands. the M-blocks were first developed in the early 70's
KF, they are very good engines but they were hurt a lot by emissions regulations that came on in the late 70's which is why stock they were looked over as possible high preformance options. When actually comparing a 72 400 with a 460, then the numbers are closer than you would think, a 460 with a 4v carb was at a 8.5:1 compression ratio in 72. a 400 with a 2v carb had an 8.4:1 compression ratio. Also keep in mind that the 400 has the longest stroke of any Ford V-8 which produces a massive amount of torque.
Old Jan 30, 2002 | 11:02 PM
fordblue_ca's Avatar
fordblue_ca
about ford 400
