Wierd Fuel Pressure Problem
Old Dec 3, 2005 | 02:15 PM
westsideblackshi's Avatar
westsideblackshi
Angry Wierd Fuel Pressure Problem
I'm having a really wierd problem on my '89 f150 (i6) w/ dual tanks. I was getting crossfeed from the rear tank to the front so i installed the OEM checkvalves indicated in the recall to fix the issue. But now, when I change tanks, i cant get enough psi to open the fuel path through the new OEM selector valve. Whats even worse is that i cant put it back on the previous tank, and get fuel flowing again. its almost like the newly installed checkvalves take all my psi away and then im just dead in the water..any help? By the way, each check valve was installed in each supply line at each tank. Because of the way they are made, you really can't put them in wrong. The selector VALVE is new OEM as well as the rear sending Unit and pump. I'm really thinking there is WAY too much resistence in the checkvalves.
Old Dec 3, 2005 | 03:12 PM
subford's Avatar
subford
I see nothing about a checkvalve fix.
<TABLE cellSpacing=0 width=624 border=0><TBODY><TR><TD vAlign=center bgColor=#c0c0c0>Campaign Number: 91V146000 Date: 1991-Sep-04 </TD></TR><TR><TD vAlign=top>Component: Fuel System, Gasoline: Storage: Auxillary Tank: Selector Devices </TD></TR><TR><TD vAlign=center></TD></TR><TR><TD vAlign=top>
Defect Summary: THE DUAL FUEL TANK SELECTOR VALVE MAY MALFUNCTION
AND CAUSE AN OVERFILL CONDITION IN ONE OF THE FUEL TANKS, RESULTINGIN AN
OVERFLOW OF FUEL PAST THE FILLER CAP.
Consequence Summary: THE OVERFLOW OF FUEL PAST THE FILLER CAPCAUSES A FUELLEAKAGE, WHICH CAN RESULT IN A FIRE WHEN EXPOSED TO ASOURCE OF IGNITION.
</TD></TR><TR><TD vAlign=center></TD></TR><TR><TD vAlign=top>Corrective Summary: REPLACE THE DUAL FUEL TANK SELECTOR VALVE.
</TD></TR></TBODY></TABLE>
Old May 7, 2006 | 11:41 PM
dldz's Avatar
dldz
Ok I've been reading and get the picture. I need this valve. Any ideas on where I can find one ? I have tried Autobones site and called a few others and they don't even know what it is. I have a 86 F150 W/ carbed 302.
Old May 8, 2006 | 04:28 AM
MBBCop's Avatar
MBBCop
I had the same problem with my 88 f250 front tank was overfilling and flowing out the cap. Changed out this Dual Functioning Reservoir and problem solved. I had to order it at the Dealer, they didnt even stock it. Not hard to change.
Old May 8, 2006 | 08:10 AM
dldz's Avatar
dldz
I was afraid of that, I wonder if someone here has a work around.
Old May 8, 2006 | 08:36 AM
subford's Avatar
subford
Do you have two fuel tanks in the Bronco?
If not what you are looking at on the Bronco is just a fuel filter and I was under the impression that they started putting these on in 1987 FI Trucks.
Old May 8, 2006 | 10:45 AM
dldz's Avatar
dldz
I'm working on my 86' F150, I just talked to Ford & they want $ 171.00 and have to order the thing. My Broncos got a whole nuther setup.
Old May 8, 2006 | 11:01 AM
andym's Avatar
andym
The recall is for fuel injected vehicles only. The return fuel line causes the overflow. You don't have a return line with a carb.
Old May 8, 2006 | 11:10 AM
dldz's Avatar
dldz
I know I need that valve because it's not opening and closing the tank flow right. I guess I'll have to find one at a bone yard.
Old May 8, 2006 | 05:33 PM
subford's Avatar
subford
Well I am not going to tell you are wrong but I would think what you need looks allot like this if you have a carburetor.
Old May 8, 2006 | 06:05 PM
dldz's Avatar
dldz
It used to be EFI but was converted over,I guess I should have mentioned that. I got the part today $20.00 at the junk yard. Thanks for everyones help.
