gear ratio for towing
Old Dec 3, 2005 | 02:06 PM
putzhall3's Avatar
putzhall3
I currently have a 97 F250 with 3.56 gears. I am looking to put some different gears and some bigger tires, right now they are LT235/85/16.
I am looking at going to a 35" tire at the biggest. My question is what gear ratio would be the best for towing a 10,000lb trailer? I was thinking maybe 4.10 or 4.56? Let me know what you guys think would be best. Thanks in advance.
Old Dec 3, 2005 | 02:08 PM
johnsonswamp's Avatar
johnsonswamp
4:88's if it's a gas burner an 4:56's if it's a diesel.
Old Dec 3, 2005 | 02:10 PM
putzhall3's Avatar
putzhall3
oh yeah sorry it is a 460
Old Dec 3, 2005 | 02:59 PM
The SnoMan's Avatar
The SnoMan
I agree, even with a 460. With 35's and a 10 k trailer it would just about be right. With a smaller engine it would be a 5.13 or deeper with that amount od weight. It is more than a effective gear ratio change here because bigger tire consume more power too to roll and add more drag to truck because of increased height..
Old Dec 4, 2005 | 06:54 AM
jowilker's Avatar
jowilker
Question, Wont the larger tires decrease the control ability of the loaded trailer. I would think trailer sway will be increased, among other things.
Some times a for looks truck ainted suited for heavy work. IMHO
John
Old Dec 4, 2005 | 08:10 AM
The SnoMan's Avatar
The SnoMan
John
Good point. Yes bigger tires can be a problem if they are running at a lower pressure. If they can handle 60PSI or more though they should be okay.
Old Dec 4, 2005 | 06:03 PM
putzhall3's Avatar
putzhall3
I am not definately going to do 35" tires but it may happen some day, for the moment I will most likely go with some 285/75/16 or 315/75/16. I definately don't want to put "looks" over towing capability!
Old Dec 5, 2005 | 05:28 AM
The SnoMan's Avatar
The SnoMan
You might look at the links below
Click Here
or
Click Here
