Bigger Injectors
Old Dec 2, 2005 | 09:35 PM
RedneckF-150's Avatar
RedneckF-150
Bigger Injectors
I have been looking for some 19# injectors to step up from the 17# injectors in the truck. I cannot seem to find any(for a reasonable price). I am NOT spending 75 bucks A PIECE for new ones, so I would like to know some junkyard motors to look for. I recently swapped in a rebuild 300, and I need to shame the people who told me to put a V8 in...
Old Dec 2, 2005 | 10:30 PM
quadzjr's Avatar
quadzjr
just another Rockwell looser
do you know if the 17# injecters come stock with 300-6's
Old Dec 3, 2005 | 07:51 AM
RedneckF-150
I'm fairly sure the 17# injectors came stock on 300's, and I heard of someone a while ago putting the 19# injectors on, but I don't know where to find them. I also have a 302 throttle body and plan on port-matching the 300 plenum to it.
Old Dec 3, 2005 | 08:27 AM
Tnehring14's Avatar
Tnehring14
lemme know how that t/b works out for ya, id be curious to know the differences. as fas as injectors, i dunno what might have the 19's. i llook around...keep us posted.
Old Dec 3, 2005 | 08:30 AM
Motorhead351's Avatar
Motorhead351
Stock 4.9's use a 14 lbhr injector.
If you step up to the larger injectors, ideally you'd reprogram the computer. Most add an adjustable fuel pressure regulator. Reason being, the stock 4.9 fuel pressure is set at 58psi or so, the v-8 engines use something closer to 39/40psi.
Old Dec 3, 2005 | 08:38 AM
Motorhead351
Look on a 5.0/5.8 engine, a yellowish orange injector top would indicate a 19lbhr injector. Some of the 5.0 car engines received a 14lbhr injector like the 4.9, it has a gray top.
or you can look on 4.0 rangers/aerostars, if you see a black top injector, this would indicate a 19 lbhr injector.
Old Dec 4, 2005 | 02:12 AM
optikal illushun's Avatar
optikal illushun
if ur 300 is stock or close to stock (bolt ons) u do not need larger injectors plain and simple.
Old Dec 4, 2005 | 06:21 PM
RedneckF-150
So, would a truck 302 have 19# injectors?
Old Dec 4, 2005 | 06:46 PM
Motorhead351
yes.............
Old Dec 4, 2005 | 06:50 PM
RedneckF-150
Sweet... I can already get some. I thought the truck 302 had the same injectors as a 300, but sometimes ignorance/stupidity rears it's ugly head over my brain function. Thanks a heap!
Old Dec 4, 2005 | 09:48 PM
quadzjr's Avatar
quadzjr
what all is involved in putting 302 throttle body on a 300? do the bolts, wiring, and air intake all match up? if i put the 302 throttle body on should i use its injectors as well?
Old Dec 5, 2005 | 10:20 AM
Motorhead351
Just make sure the injector is the correct color, if the injectors on the 302 your looking at are GRAY in color, leave them, GRAY is 14 lbhr.
Old Dec 5, 2005 | 07:49 PM
optikal illushun
again u never answered my question, why do u think u need the larger injectors? of ur engine is stock or with a few bolts ons they are not needed.
Old Dec 6, 2005 | 09:45 AM
Motorhead351
Something else to consider and a good reason to either use an adjustable fuel pressure regulator or reburn the computer.
Right now you have a 14 lb hr injectors that operates at 58 psi
You wanna add in the 24lb hr injectors that normally operate at 39 psi
I am not 100% sure what psi each is rated at but for this, we will say the stock fuel psi setting.
If you take a 24lb hr injector rated at 39 psi and increase the fuel psi to 58 psi, which is the stock 4.9 setting, your 24 lb hr injector will flow 35 lb hr.
Using a injector flow/ HP support formula
14 lbhr = 135
24 lbhr = 240
35 lbhr = 336
This is with BSFC being .5 and duty cycle .8, # injectors 6
Old Dec 6, 2005 | 01:20 PM
Silver Streak's Avatar
Silver Streak
Almost all injectors are rated at 3 bars (43.5psi). A 24 lb/hr injector running on the stock fuel pressure regulator will make the truck undriveable, been there, done that. Even with the adjustable regulator I couldn't get it to run good enough to drive. It was gutless and got about 4 mpg. At 60 psi a 24 flows around 33 lb/hr; nearly double what the engine needs.
