Problems running
Old Dec 2, 2005 | 02:00 PM
rydog2582's Avatar
rydog2582
Cool help
i have a 1966 ford f100, with a 351c, it keeps on dying. the starter is good, the alternator is good, i unplugged the electric choke and it started right up yesterday, and it started up this morning, but then it died, what do i do? i killed the battery trying to get it started.
Old Dec 2, 2005 | 06:03 PM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome rydog2582, to Ford Truck Enthusiasts!
…..See you on the boards.
Old Dec 4, 2005 | 06:47 AM
danlee's Avatar
danlee
Why did you unplug the electric choke?
What did it do before you unplugged the electric choke?
The electric choke needs power to open it when it is at low temperatures. If it stays closed the mixture will be rich and your plugs will get wet. Then it will not start.
Old Dec 7, 2005 | 08:49 PM
81broncoguy's Avatar
81broncoguy
Check your fuel filter, I recommend getting a clear fram fuel filter because it's easier to see if you're getting fuel. Also you might try some carb cleaner on the carb and adjust your fuel mixture screws on the carb. Worse case scenario you might have a fuel pump that needs replacing if you're not getting enough gas to the carb.
dcelrod
Sep 24, 2014 05:15 PM
wes2k3
20
Aug 6, 2013 10:30 PM
FirstTimeDiesel
New Member Introductions
Oct 3, 2012 03:41 PM
Hmann
Mar 9, 2010 09:23 PM
packmule911
Mar 15, 2005 07:25 AM
