BIO-Diesel???
Old Jan 8, 2006 | 11:31 AM
  #31
rcdallas's Avatar
rcdallas
Originally Posted by johnny19
It went down to 11 last night so today should tell me something - do you mean that the B20 has to be de-watered? I didn't think so. How do you do it?
No B20 that you buy at the pump you do not dewater it. You shouldn't have to do anything to it.
I was refering to running vegetable oil - close cousin of biodiesel two different things.
Well it's past noon, your truck running fine?
Old Jan 9, 2006 | 07:00 AM
  #32
johnny19's Avatar
johnny19
thanks - I really want to keep using the bio so I'll just watch my separator carefully! I'll be checking out different suppliers too.
Old Jan 9, 2006 | 07:02 AM
  #33
johnny19's Avatar
johnny19
truck running fine - supposed to go up in the 40's today anyway! thanks
Old Jan 10, 2006 | 08:23 PM
  #34
smid87's Avatar
smid87
Any amount of Bio can be run in the winter, but it must be heated or treated. Problem is there is no good additives out there to help the gell point. Plenty that help the CFPP, but then you get a solid gold blob instead of a solid white blob. If you ask me it is actually worse as it makes it harder to see the gelling. If you are using B20 (I am) you should be just fine all winter. I use B20 in my 99 F250 and I have not had any issues except at start-up when I do not plug it in, it surges for a few seconds then clears right up. Keep on Biodieseling.
Old Jan 11, 2006 | 06:16 AM
  #35
johnny19's Avatar
johnny19
OK thanks - so far so good - it's been real warm anyway!
Old Jan 11, 2006 | 12:17 PM
  #36
moe.scott's Avatar
moe.scott
Hello, I'm a new member with a new to me 99 PowerStroke, In Vermont bio-diesel is becoming more available and I have filled up with B-20 several times since I have owned my truck. I have no negative feedback on the subject of using bio. In fact it was the primary reason for the purchase of my truck. For all those still on the fence about the issue of bio-diesel use, I highly recommend a book called "From the fryer to the fuel tank." This book provides good detailed info on almost everything dealing with using veggie oil as an alternative fuel, it also deals in depth with conversions to burn straight vegetable oil in your diesel.
Old Jan 11, 2006 | 05:54 PM
  #37
cookie88's Avatar
cookie88
FTE Leadership Emeritus
FTE Emeritus
Welcome to Ford Truck Enthusiasts moe.scott!
Sounds like an interesting read....thanks.
Old Jan 12, 2006 | 06:10 AM
  #38
plumbguy's Avatar
plumbguy
***** nelson has a website telling about bio diesel. I was wondering of biodiesels lubricity. I also heard that the biodiesel takes away alot of the compustion clatter and cleans the engine and fuel system, I have heard of people switching to it and having to change the fuel filters out because of all the crud it breaks loose. who knows.
Old Jan 12, 2006 | 06:33 AM
  #39
Kwikkordead's Avatar
Kwikkordead
All what you say is true. Once the fuel filter switcharoo is over than it's back to normal.
Old Jan 12, 2006 | 07:12 AM
  #40
johnny19's Avatar
johnny19
Thanks - I am definitely gonna stick with the B-20. And in the warmer weather I'll try B-100.
Old Jan 12, 2006 | 07:33 AM
  #41
Kwikkordead
Johnny I've run as high as B-50. Great stuff.
Old Jan 12, 2006 | 10:34 AM
  #42
willbd's Avatar
willbd
I have been running B99. Reduced smoke on startup, smother running engine, no diesel smoke smell. The only problem is not enough pumps pumping Biodiesel yet.
Old Jan 16, 2006 | 02:12 PM
  #43
schefner's Avatar
schefner
Anyone know what the gelling point of B100 is?
Old Jan 16, 2006 | 02:49 PM
  #44
cookie88's Avatar
cookie88
FTE Emeritus
I think I've read that it starts getting thick as high as 40F.
Old Jan 17, 2006 | 04:03 PM
  #45
schefner's Avatar
schefner
thank you.
