wheel studs
Old Dec 2, 2005 | 01:33 PM
snagmaster86's Avatar
snagmaster86
wheel studs
hey, I have a '79 F-250. Before it became mine, it had a set of wheels put on that were off of an old van. Long story short, they didn't fit right and the left rear came loose and tore up the wheel studs and fell off. Now I need to replace the studs. Do I have to take the whole drum brake assembly off to change the studs? please help.
P.S. crappy wheels are being replaced by brand new American Racing wheels!
Old Dec 2, 2005 | 02:06 PM
beartracks's Avatar
beartracks
Yes take the drums off. Unfortunately you will probably have to pull the axles too and then hammer/press the studs out the back of the axel flange. Good choice on the new wheels.
Old Dec 2, 2005 | 02:14 PM
seventyseven250's Avatar
seventyseven250
I was able to hammer the studs out on my 77 F250 with a small sledge and a punch. Took quite a bit of hitting, but they all come out in the end.
Get some ear protection, that can get quite loud.
Old Dec 2, 2005 | 05:00 PM
MBBFord's Avatar
MBBFord
I have some messed up studs on one of my rear wheels, and was wondering what you ment by you will have to pull the axles too? I have never done this, but would like a little more light on this subject please(what all needs to come off?).
Thanks for any help.
Old Dec 2, 2005 | 10:52 PM
snagmaster86
How serious of a job is pulling the axle going to be?
Old Dec 3, 2005 | 07:12 PM
plowpusher's Avatar
plowpusher
79 f250 should have the "60" ful floater rear axle to remove the studs you have to remove the wheel tire assembly, axle (5/8 headeed bolts in the center)then the two locknuts and lock washer then the drum will come off the just use a flat endeed punch and knock out the studs get new studs and rear wheel seal at your auto store start them with a tap from your hammer and pull them in with a wrench or air gun replace the seal you really should get a manual to do this or go to the library and look at the referance section its not a hard job but reassembly must be done right
Old Dec 4, 2005 | 03:55 PM
bob arrington's Avatar
bob arrington
next time get a bigger hammer and just hit them once each,bob
Old Dec 4, 2005 | 05:33 PM
User 71024's Avatar
User 71024
I've never had to pull an axle to replace the studs.
Old Dec 4, 2005 | 06:54 PM
MBBFord's Avatar
MBBFord
EricJ, did you just pull off the drum and hit them out or what?
Old Dec 6, 2005 | 02:08 AM
tomcasino's Avatar
tomcasino
I don't remember what year(s) it was but some F250's did have semi-floating rear axles. Just like the 1/2 tons only with 8 lug nuts. I don't know what the advantage was but they did make them.
Old Dec 6, 2005 | 07:53 AM
User 71024's Avatar
User 71024
Yes, if your replacing them, then just drive them out, you'll want to rotate the axle til it's in an opening so you don't hurt the brakes, but then just drive them out.
to install, place the stud in the hole, stack as many greased washers as will fit and use the lugnut backwards so it has a flat side to draw it in.
Old Dec 6, 2005 | 07:54 AM
User 71024's Avatar
User 71024
ya that was a glorified half ton truck, I think they made them to appease the wannbe truck owners that were buying f-250 to use as a car because it was"cool".
Old Dec 6, 2005 | 10:05 AM
snagmaster86
yea my '79 f-250 has the semi-floating axle in the rear......kinda disappointing
