Engine Dies
Old Dec 2, 2005 | 04:14 AM
romcjr's Avatar
romcjr
Engine Dies
I'm sure this has been answered before,but recently my truck has started dying when I let off the gas abrubtly when approaching a stop.If I let off gradually it's o.k..What things should I check?Thanks,Ron.
Old Dec 2, 2005 | 05:45 AM
bilder12's Avatar
bilder12
Have you recently done any repair work to the fuel system ? Do you see any fuel leaking from top of injectors ? How full are the fuel tanks ? When is the last time yo changed the fuel filter ?
Old Dec 2, 2005 | 07:27 AM
PLC7.3's Avatar
PLC7.3
Could be a weak fuel pump............
Take the Schrader valve core out and hook a hose and pressure guage to the outlet.........crank engine see what you get for pressure, should have 4-6 psi from a good lift pump.
Volume test same place hook a hose to it crank over the engine 10 seconds you should get 1/3 pint of fuel minimum or 1 pint at 675 rpm in 30 seconds... engine running
Important the fuel shutoff solenoid (FSS) wire on the IP should be disconnected if you do not want a start just cranking. Re connect FSS after test complete.
Old Dec 3, 2005 | 04:14 AM
romcjr's Avatar
romcjr
Both tanks are full,I have about 3k miles on the filter(what is normal change freq ?).I will change it and I will check fuel pump.Thanks for your help,Ron.
Old Dec 11, 2005 | 12:48 AM
shrek13's Avatar
shrek13
i have the exact same problem with mine. i just changed the fuel filter today, and the injector o rings 2 weeks ago, they are no longer leaking. i have found some other usefull info to check out, email me and i will send it. kylecott@hotmail.com
Old Dec 11, 2005 | 06:13 PM
wh336fire's Avatar
wh336fire
Contaminated fuel or a bad ip can cause this problem . Mine was doing this untill I changed my ip . I have read on here where you can take the top off of your ip and clean it out to fix the problem . Maybe someone with more ip knowledge will help you with this one .
Old Dec 11, 2005 | 07:46 PM
IHdieselfan's Avatar
IHdieselfan
I change my fuel filter when i change the oil, But I work with heavy equipment in all the dust and crap. if you stay on the road i would go with every other oil change.
