Oil & Lubrication
Oil Filter study...Your thoughts????
Old Dec 1, 2005 | 11:15 PM
Night_Ranger's Avatar
Night_Ranger
Just wanted to post this link to a filter study I found.
Any thoughts????
I was surprised by the low rating of Fram filters, which is probably the most popular out there, by sales numbers.
http://minimopar.knizefamily.net/oilfilterstudy.html
Old Dec 1, 2005 | 11:53 PM
ford390gashog's Avatar
ford390gashog
that study is very very old. BIG O DAVE did his own. check his threads in this forum. yes fram is the bottom of the barrel filter with a porsche price tag. even the walmart supertech filters are better and cost 2.00
Old Dec 1, 2005 | 11:58 PM
Hootbro's Avatar
Hootbro
Other than the Frams still being junk, that study is somewhat outdated. The A/C Delco and a few others have changed designs depending on the application. The main bone to pic with Fram is that they are a marginal design that does work but the price they charge is not warranted for what you get. Many house brand filters not Made by Fram can be had for less and are twice the filter in terms on construction quality.
Go here for all things oil and oil filters: http://theoildrop.server101.com/cgi/ultimatebb.cgi
Old Dec 2, 2005 | 12:28 AM
Night_Ranger
Thanks for the link.
I am trying to find the best for my engine. I have a Ranger 2.3l 4banger. I run Mobil 1 5-30 in it and am looking for the best filter I can find at a reasonable price. Anyone have any thoughts on which oil filter would the bill?
Old Dec 2, 2005 | 12:29 AM
ford390gashog
that would be Motorcraft or wix. and either 5w20 or 5w30 Motorcraft oil.
Old Dec 2, 2005 | 08:56 PM
Flash's Avatar
Flash
Don't try to read too much into any oil filter study where the filters are cut open and then the amount of media is determined. Some will use more media and some less. Some with tight folds, some with loose folds. In no study is the porosity capacity ever stated. If you have alot of media but it lets everything thru, what have you gained? If you have less media but it traps everything to 3 microns, what have you gained when it goes into by-pass because it is clogged? Buy a reputable brand like Wix or Motorcraft and know you have the best compromise possible for your engine. Filter studys, while interesting, are not a reliable test criteria. The Beta Ratio, which is a rating of the filters efficiency, is also suspect as the temperature of the fluid is a variable, the pressure a variable, the rate of flow, the basestock used, and it goes on. I would stay away from Fram for obvious reasons to those that frequent this forum. Just stick with a name brand that isn't orange.
Old Dec 4, 2005 | 11:00 AM
99F150's Avatar
99F150
Ok I have a question. I have four cars that are used on a regular basis and each uses a differnt filter. The 65 F100 uses a FL1A, the 99F150 uses a FL400S, the 87 TBird Turbo uses the FL300 and the 2005 Escape uses the FL910. All four of these has the same thread, gasket size etc. They all have a bpass and anti drain back valve. Assuming that an FL1A will physically fit or that I use a remote mount for those that it don't is that filter acceptable for each application? I would like to stock and use one filter for all four cars. If the FL1A is not the best what would be?
Thanks
Dan
Old Dec 4, 2005 | 01:04 PM
T- Squared's Avatar
T- Squared
You should be good to go if the 1A's bypass psi's match the other filter's.
Old Dec 4, 2005 | 02:08 PM
ford390gashog
they all have the same bypass setting. another interesting thing the fl1a has a better micron rating.
Old Dec 4, 2005 | 07:02 PM
99F150's Avatar
99F150
I just don't understand why the FL1a was not used on the Escape or the F150. I have not trted to mount the FL1A but I have Plenty of space. The Turbo coupe will need a remote mount due to the steering shaft being in the way.
Old Dec 4, 2005 | 07:04 PM
Flash's Avatar
Flash
Any time you use a larger filter, the system will take a little longer to become fully pressurized. It may not sound like much but I wouldn't run anything but the recommended filter.
Old Dec 4, 2005 | 07:24 PM
ford390gashog
the thing is, you do not need a bigger filter than stock. so i would leave it alone. the engine does not produce enough by products to warrant the use of a extra big filter.
Old Dec 5, 2005 | 09:53 AM
99F150's Avatar
99F150
I guess I am trying to simplifiy things more than any thing by having to buy only one filter. Also the FL1A is considerably less expensive than the 910 on the Escape. Also the filter on the Escape is verticle, so no oil will drain out. Will it still take longer to build pressure?
Thanks Dan
Old Dec 5, 2005 | 02:34 PM
ford390gashog
walmart here sells the 910 for 3.28.
Old Dec 10, 2005 | 02:57 AM
Hootbro's Avatar
Hootbro
Still inside a warranty, I am not a fan with oversize or different size filters. Warranty coverage can be denied by both the vehicle manufactuer and the oil filter vendor if a non cataloged size is used even if it is a defective filter.
