down a couple
Old Dec 1, 2005 | 08:11 PM
10 pipes racing's Avatar
10 pipes racing
down a couple
hey ford fan!!! just wondering about oil levels in between changes. been towing toys the last couple of months, and was due for a change. it was above the add line, down about 1.5 quarts. is this normal? how much do you folks add between changers. thanks for your time.
Old Dec 1, 2005 | 08:41 PM
NE MACHINERY's Avatar
NE MACHINERY
I rarely add any oil but I notice that after 5000 miles that it is down around the add mark. Towing or not. I see no reason to add any as long as it is above the add mark. I see many large cat engines that have to run at the add mark or the crankcase will blow it out anyway.
Old Dec 1, 2005 | 08:51 PM
JOE-M's Avatar
JOE-M
Different trucks, different levels on the dipstick. Mine doesn't use any over 5000 miles but others use a quart or more between changes. If it is using a quart and a half I think I'd fill it back up. If it just used a half a quart or so and then stopped, I'd run it that much low all the time.
Joe
Old Dec 1, 2005 | 09:03 PM
CAT_man_963's Avatar
CAT_man_963
Like JOE-M said - each truck is a little different - but it is not abnormal to be a little low when it's time for an oil change. My truck is usually about a quart low when it's time to change the oil - if I do a lot of hard driving, or towing - it will use a little more. It's completely normal for a turbo diesel to use some oil.
Old Dec 1, 2005 | 09:58 PM
10 pipes racing
Thumbs up
well you can tell were i came from by my name. that was a 99 250 too, and it used no oil at all. so when i seen it was down, i thought i would drop a line to my fte friends and get to the bottom of it. new to 7.3 but learning every day! thanks a lot friends.
Old Dec 2, 2005 | 01:47 PM
Wings's Avatar
Wings
What I have heard or read is, that if the oil gets too low you will start losing pressure at the HPOP, which will effect you fuel injection. If I were down below the add line, I would at least add for comfort level. I don't drive my PSD more than 6000 miles per year and I use synthetic oil. So my changes are once a year whether I need it or not.
