clutch adjustment
Old Jan 29, 2002 | 07:17 PM
Southern Fried's Avatar
Southern Fried
clutch adjustment
Im having problems getting into gear sometimes. I got a 3spd on the column. I was wandering if I could adjust the clutch to help it. It has been years since I adjusted one so I dont remember how to do it. I mean I dont know what to set it at or which direction to go with the adjustment. Any advice?
Old Feb 2, 2002 | 08:39 AM
Trail_Rider's Avatar
Trail_Rider
clutch adjustment
Take a look at your front cab mounts first. If they are rusted and the cab is sagging on the frame it causes shifting/clutch problems especially on 3 speeds.
Trail Rider
Old Feb 2, 2002 | 01:28 PM
xcopterdoc's Avatar
xcopterdoc
clutch adjustment
If the clutch isnt disengaging enough it will cause a hard shift condition. Adjust the clutch for 1 to 1.25 inches of play at the top of the pedal.. free play... this is the distance between the throw out bearing and the pressure plate. Go from there.
Old Feb 2, 2002 | 03:35 PM
Southern Fried
clutch adjustment
OK thanks! I knew it was something like that but couldn't remember the actual measurement.
Old Feb 2, 2002 | 03:37 PM
Southern Fried
clutch adjustment
Yeah thanks but its a southern truck not too much rust...none actually.
Old Feb 2, 2002 | 03:43 PM
FTE Ken's Avatar
FTE Ken
clutch adjustment
