Sponsored by: Real Truck
wireing 7 way
Old Dec 1, 2005 | 12:41 PM
cabldawg's Avatar
cabldawg
wireing 7 way
My truck did not come with the 7 way plug mounted on the rear. It already has all of the wiring back there though. Can anyone please tell me which wire goes to which pole on the plug?
Thanks!
Old Dec 1, 2005 | 12:58 PM
FortyFords's Avatar
FortyFords
1-yellow
-2white
-3darkblue
-4dark green
-5orange
-6brown/white tracer
-7black/light green
Rich
Old Dec 1, 2005 | 12:59 PM
cabldawg's Avatar
cabldawg
Thanks! That was fast
Old Dec 1, 2005 | 01:49 PM
krewat's Avatar
krewat
FTE Leadership Emeritus
I think Rich has a lot of time on his hands
Old Dec 1, 2005 | 05:21 PM
FortyFords's Avatar
FortyFords
No not really but I have you guys in the shop with me all the time.
Wireless computers and laptops are a wonderful thing
plus I was having a caffe,after greasing my snowmobiles.
Once we get snow,I'll be on a little less.
Rich
Old Dec 5, 2005 | 07:06 PM
cabldawg's Avatar
cabldawg
I got it all wired up the other day. The wire that is labeled for left turn/stop has no power on it. Where could this problem be originating? The harness is in perfect shape. The left turn/stop works fine on the truck.
Old Dec 5, 2005 | 10:50 PM
FortyFords's Avatar
FortyFords
You didn't ask for that part!!! LOL Sorry my fault.
Your truck didn't come with a trailer pkg so!
You need to get 2 relays from the Dealer k353,k352
Under the hood on the driverside is a auxillary relay box.
you will find 2 empty spots.
I will see if I can get p/n for you
Rich
Old Dec 6, 2005 | 06:51 AM
cabldawg's Avatar
cabldawg
I have the 2 relays and fuses. The were in the glove box. I installed a Prodigy brake controller. That works perfect. I just don't have a left turn or stop light. Everything is good on the trailer. I can hook it up to my Expedition and it works fine. The wire labeled for left turn/stop has no power.
Old Dec 6, 2005 | 07:31 AM
FortyFords's Avatar
FortyFords
So pin 1 in the 7 pin connector at the back of the truck has no voltage when the truck directional is working ??? Is this what you mean?
Did you chk fuse 6
Rich
Old Dec 6, 2005 | 08:48 AM
cabldawg's Avatar
cabldawg
In the fuse box under the dash there isn't a fuse in position 6. What size fuse should go there?
Old Dec 6, 2005 | 08:56 AM
FortyFords's Avatar
FortyFords
20 amp
Rich
Old Dec 6, 2005 | 03:38 PM
cabldawg's Avatar
cabldawg
Position 6 is just a blank. There's no connection in the slot.
Old Dec 6, 2005 | 04:11 PM
FortyFords's Avatar
FortyFords
this a 2000 truck look at position 4 in the fuse block ,still 20amp
I looked at a 02 diagram. My mistake.
Then you should do a test with a test light at the connector before you try the trailer.
Rich
