cold idle??
Old Nov 30, 2005 | 08:44 PM
cwt580's Avatar
cwt580
cold idle??
my 2000 starts and idles good on cold mornings but after a few niutes it idles up to about 1200 until i either push in clutch or touch gas pedal. comes down then back up after serveral secs or so. only does it when its cold.
Old Nov 30, 2005 | 08:54 PM
marvinlong's Avatar
marvinlong
they are supposed to. as the temp goes down to around 35deg the engine will go up to about 850 rpm,s. i forget what this is called,it has to do with wet-stacking i think. someone will chime in shortly and correct me. dont worry though,they all do it.
Old Nov 30, 2005 | 09:05 PM
Budkole's Avatar
Budkole
yep, mine does the same thing. Wont hurt it at all, it actually helps it by idling high. The high idles heats the engine faster and lets you use the heater to blow hotter at idle in cold temps
Old Nov 30, 2005 | 09:12 PM
cwt580's Avatar
cwt580
cool makes me happy!!!!!!!!!! i only put 34 miles on it since i got it.....it sure is pretty though. Had the filters changed and washed it. Been sitting awhile at the repo lot!!!
wife thinks i over did it on this one but she loves the room for those long road trips with the trailer.stereo installed last weekend. Backup cam and dvd by new yrs.
Old Nov 30, 2005 | 09:15 PM
kawika's Avatar
kawika
Last few weeks, mine has started to do this (high idle) due to the temperature. Also the EBPV is starting to close and has that hissing sound out of the tail pipe. Suppose to help heat up the engine faster. All the EBPV does on mine is to limit my speed (to <20 mph) until it warms up a little. I have to make sure I plug it in at night.
__________________
01 F250 7.3 PSD CC 4x4 Lariat Auto
Skyjacker 6" lift
35in BFG Tires
A.R.E Cap
Viper Alarm
K&N FIPK w/Filter wrap
3 Gauge A-Pillar
hpx mod, Preadator Tuner
4in Exhaust Turbo back
marvinlong's Avatar
marvinlong
missed it
