rear swap
Old Nov 30, 2005 | 08:38 PM
droppedf150's Avatar
droppedf150
rear swap
I have a 63 f100 shortbed unibody and I was wondering if anyone has swapped a rear from a late model expedition or f150 with the big disk brakes?
I have one that needs gears and was considering putting it in with a four link and air bags.
Old Nov 30, 2005 | 09:01 PM
Putt's Avatar
Putt
I think the issue would be the width of the newer housing and axles, if you have a way to shorten the parts and move the spring perches it can be made to fit.
Old Nov 30, 2005 | 09:07 PM
droppedf150
I didn't measure the width of the axle yet. If it is close I am going to cut all of the brackets off of the expedition rear and weld a four link kit to it.
Old Dec 1, 2005 | 08:29 AM
66beater's Avatar
66beater
your wheel bolt pattern is going to be diffrent, and the modern axles are 4 to 6 inches wider. You might look at an explorer axle. Its an 8.8, around 59 inches wide, and all of them after '99 have disc brakes
Old Dec 1, 2005 | 08:32 AM
droppedf150
Thanks will check into that
elliot
Apr 5, 2017 09:28 PM
mainefordman
1997 - 2003 F150
Nov 3, 2015 07:47 PM
fordsford11
Washington Chapter
Jan 22, 2012 12:41 AM
slickeast
Oct 11, 2010 10:45 PM
Duct Tape Racing
21
Aug 15, 2010 04:17 PM
