General Automotive Discussion
tire sizes
Old Nov 29, 2005 | 08:44 PM
tomrooster-1's Avatar
tomrooster-1
tire sizes
can somebody please tell me the difference between 265/75/16 and 265 /70/16
I'm thinking it's the height of the tire, so the 70 tire will be a little lower? Thanks, Tom
Old Nov 29, 2005 | 08:52 PM
F15090300's Avatar
F15090300
Close, but not actually correct...
First off, the first number (265 in this case) is the width of the tire in cm.
The second number (75 or 70 in this case) is the aspect ratio of the tire, expressed in percent. Which basically means that 75% of the tire is between the wheel and the tread.
So the 70-series tire will be lower, but not because of the height, per se.
Though I may not be 100% in my wording, this should answer your question.
Old Nov 29, 2005 | 08:54 PM
ford4.9's Avatar
ford4.9
your right about the height. here is a web site to play with the differrent tire sizes
http://www.project33.com/tiresize.cfm
Old Nov 29, 2005 | 09:20 PM
jroehl's Avatar
jroehl
In cm?!? That's a pretty wide tire...I'm 183cm tall (that's an even 6' for most of us...). Try millimeters.
The second number is height of the sidewall expressed as a percentage of the width. So a 265/70/R16 is 265mm wide (~10.4"), with a sidewall height of about 7.3" (10.4" x 70%), with a rim diameter of 16", that's an overall height of 16" + 2(7.3")=30.6", give or take. Add about another inch to overall height for 75 tires.
Jason
Old Nov 30, 2005 | 06:07 AM
Greywolf's Avatar
Greywolf
Larger truck tire sizes are much simpler!
What you see is what it is, in height width and rim size.
Old Nov 30, 2005 | 09:40 AM
F15090300's Avatar
F15090300
Jason
Yeah, thanks. My mistake.
Old Nov 30, 2005 | 10:56 AM
jimandmandy's Avatar
jimandmandy
Also understand that the 70 will have a lower load capacity than the 75 of the same load range (ply rating). This is due to the difference in internal air volume. Be careful when going to a lower profile tire of the same width, make sure that the load@psi gives you sufficient safety margin (20-25 percent for "P" sizes) for your axle loading.
Jim
