Frame work?
Old Feb 4, 2002 | 11:00 PM
MeAn351Modifed's Avatar
MeAn351Modifed
Frame work?
I have a crack in my frame on my 1977 f-250 4x4 on the drivers side just about a foot and a half behind the bed. I was wondering if anyone has had a cracked frame and how they went about fixing it,if anyone has done it with out a welder that would be Great cause i don't have one of those toys yet. Its Not a large crack aboiut 3 inches in long from the bottom of the frame up. P.S. never let your friends haul a horse trailer with a truck they can't handle
Old Feb 6, 2002 | 10:23 AM
73Custom's Avatar
73Custom
Frame work?
[font color=red size=2]In my opinion it should be welded. If you don't have the tools, then take it to a welding shop and have them fix it.
Marty
Old Feb 6, 2002 | 10:50 AM
beartracks's Avatar
beartracks
Frame work?
Disconnect the battery before welding to save messing up ignitions,stereos etc.
:-staun
Bear
Old Feb 7, 2002 | 03:35 PM
fatdaddy's Avatar
fatdaddy
Frame work?
As part of the "fixing" process you should consider adding a gusset--steel plate on the Outside of the frame maybe---3/8" thick by 3" or 4 " wide by maybe 6" long , weld the crack on the Inside and put a couple of grade 8 by 1\2" bolts on both sides of the break , welding(heat) can weaken a piece of steel under certain circumstances and is not always the best fast fix that everybody would like for it to be!!!-something to think about , fd :-X11
Old Feb 7, 2002 | 04:15 PM
dfisher1's Avatar
dfisher1
Frame work?
