Gas Door Problem
Old Nov 29, 2005 | 03:40 PM
centerfield's Avatar
centerfield
Gas Door Problem
Hi all...anyone having a problem with their fuel door not staying open when pumping gas? This just started on my '04 F-150 with 24K. Suggestions?
Old Nov 29, 2005 | 09:28 PM
xtrm1stang's Avatar
xtrm1stang
The fuel door has a return and hold spring that will come out of place, since your under warranty it should be no problem to fix, they just need to replace the fuel tank door hinge assembly. That is seperate from the door itself that is painted. Takes only 10 min to do this, provided thay are able to get to it right away.
Old Nov 29, 2005 | 09:41 PM
FS-150's Avatar
FS-150
Centerfield, you are lucky, mine broke @ 2k miles. It is an easy fix for the dealer just as xtrm1stang suggested. Just call ahead to make sure they have one in stock.
Old Dec 1, 2005 | 04:53 PM
centerfield
xtrm1stang - Thanks for the good advice on a small issue, yet one that needs to get fixed!!
Old Dec 1, 2005 | 04:56 PM
centerfield
FS-150 - Thanks too, I'm fortunate that this is the only issue I've had thus far!
