Auxilary Amp Meter Connection
Old Nov 29, 2005 | 01:27 PM
59INA40's Avatar
59INA40
I have installed an oil pressure gauge and an ammeter in my '66 F100. The oil pressure gauge is pretty obvious and works well. The instructions for the ammeter says to remove all of the wires from the battery side of the magnetic starter switch (solenoid) except for the starter cable and connect a 10 or 12 gage wire from the gauge to that terminal. It then instructs you to connect the other wire from the ammeter to all of the wires that were removed from the battery side of the solenoid. I can see how the current flows but I am having trouble asking a 10 or 12 gage wire to handle the load of all of the other wires, especially considering that a couple of them look to be 4 or at least 6 gage. Any thoughts on this. Is there a more direct way to wire in the ammeter on a Ford? I put one on my '40 flathead (12V conversion w/one wire GM alternater) and a wire runs from the alternater through the ammeter and then connects to the positive side of the solenoid. Thanks for putting on the thinking cap for me. Steve
Old Nov 29, 2005 | 02:10 PM
PROSTOCK's Avatar
PROSTOCK
Those instruction are correct...that's the way the factory installed gauge works. You can use a heavier wire if it makes you more comfortable.
Old Nov 30, 2005 | 09:37 AM
daveengelson's Avatar
daveengelson
Believe the factory installed gauge used a junction block between gauge and solenoid. May be able to run a heavier gage wire to the solenoid side, and lighter gage from solenoid to instrument. Perhaps member more knowledgeable in electrical circuits can advise. Have a 65 with amp gauge but have not connected up yet. Considering a fuse type junction block if/when I do hook it up.
dave
Old Nov 30, 2005 | 04:46 PM
John D.'s Avatar
John D.
I have found that a volt meter is more useful to me than an ammeter. Unless your battery is real low and taking a hefty charge or you have a lot of heavy drain accessories, an ammeter doesn't give much of an indication. Don't get me wrong, it's a useful instrument, I just feel better about knowing the battery terminal voltage.
John
Old Dec 2, 2005 | 09:58 AM
59INA40's Avatar
59INA40
John, the volt meter idea has merit. Does it connect the same way as the ammeter? Steve
Old Dec 2, 2005 | 12:48 PM
PROSTOCK's Avatar
PROSTOCK
NO if you do it'll fry!! Just hook the positive side to any power source, preferably at the battery, and the other terminal goes to a ground...much simpler than an ammeter and no heavy gauge wire is required. If there are charging issues you will also have the "idiot" light to clue you in.
Old Dec 2, 2005 | 08:28 PM
59INA40's Avatar
59INA40
Prostock, thanks for the instructions. I don't have a volt meter yet but when I get the ammeter wired up I will put in a volt meter as well. I have a three gauge mount but only two gauges so a volt meter will fill the unused hole. Thanks, Steve
Old Dec 2, 2005 | 09:35 PM
ford390gashog's Avatar
ford390gashog
well the amp meter gets wired a little different than waht you said in the instructions. on the alt find the heavy guage wire should be purple. run it from the alt to the guage then from the gauge back to the wire which heads to the starter solinoid. i will post a pick if you need one.
Old Dec 3, 2005 | 09:17 AM
59INA40's Avatar
59INA40
Gashog, your wiring method is more in line to what I have done with my '40. But it conflicts with what the instructions and another post here tells me. Instead of clarity, I'm getting confusion and I already have enough of that in my life. Anybody got a third opinion? Steve
Old Dec 3, 2005 | 05:40 PM
Putt's Avatar
Putt
According to Autometer, the ammeter should be inline with the alternator output wire and nothing else. The typical Ford small case alt. puts out a max of 63 amps, I would estimate about 10-12 feet of total wire length to the ammeter. According to my wire gauge chart a 12 gauge wire will handle 50 amps for a 10 foot run, an 8 gauge wire will handle 100 amps.
HTH, and hang in there, wiring is sometimes hard to explain in writing!!
Old Dec 3, 2005 | 07:04 PM
Torque1st's Avatar
Torque1st
Posting Legend
Personally I would not use an aftermarket ammeter. I have seen too many fires and burned wiring. A voltmeter is much easier to wire in and far less dangerous. A voltmeter gives much better information IMO.
Old Dec 3, 2005 | 08:30 PM
Putt's Avatar
Putt
I agree on the safety issue, Eric. I have both at this time and find the two together sometimes gives some added info...if you watch them. The voltmeter is definitely much safer.
Most of those fires and burned wiring were likely caused by poor wiring connections or insufficient wire size for the amperage output, IMO anyway.
Old Dec 4, 2005 | 02:28 AM
RickyD's Avatar
RickyD
On my son's 66 we installed a volt meter in place of the factory ammeter. We just bolted the ammeter wires together and insulated well. Then ran a small wire from the ign. switch to the voltmeter. Works great.
Old Dec 4, 2005 | 06:10 PM
66Ford my baby's Avatar
66Ford my baby
The instructions that came with the ampmeter are correct.
If you put the ampmeter on the alernator wire to battery you will read the output from alternator to all acc. and battery.
Just make sure the connectors are on tight and to be sure solder them with rosion core solder.
Old Dec 4, 2005 | 09:38 PM
59INA40's Avatar
59INA40
Thanks 66 and all that have responded to this thread. I picked up some 10 gage wire and will follow the directions from the manufacturer. Will let you all know how it turns out. My son has the truck at college but will be home for the holidays in about a week. Steve
