88 E150 problems
Old Nov 29, 2005 | 11:33 AM
SonnyD's Avatar
SonnyD
88 E150 problems
How would I go about connecting the power to the blower to see if the blower works ? I unpluged the connector off the blower resistor. would it be as easy as touching a hot to one of the connectors ?
Also I unpluger the blower resistor connector and fired up the motor. I am getting 14V to ground on one connection, I am assuming the other end is the blower switch. I am looking at a diagram and I dont see where the voltage is introduced
Any ideas
Old Nov 29, 2005 | 12:15 PM
subford's Avatar
subford
Any ideas
If this is the diagram then it comes in at the top right.
Old Nov 29, 2005 | 01:34 PM
SonnyD's Avatar
SonnyD
thanks
Where did you get the diagram ? I cant blow it up and my eyes arent what they use to be.
Old Nov 29, 2005 | 02:10 PM
subford's Avatar
subford
I got it from:
http://www.autozone.com/images/cds/g...3d800a39e7.gif
Old Nov 30, 2005 | 08:08 AM
SonnyD's Avatar
SonnyD
Thanks, got the parts and will fix it today.
do you know of any other sites that are about e150's ?
Also do you know if the 88 has any OBD ports ?
Thanks again.
Old Nov 30, 2005 | 08:24 AM
subford's Avatar
subford
[QUOTE=SonnyD]Also do you know if the 88 has any OBD ports ?
QUOTE]I take it you are talking about "On-Board Diagnostic", Yes there is a Test Plug Behind the right passenger head light. There is also a single wire hanging with it that is used at the same time.
Here is a diagram of it.
Old Nov 30, 2005 | 11:23 AM
SonnyD's Avatar
SonnyD
you are the man, thanks. will any reader work ?
Just fixed my heater. now all I have to do is bang around where the battery sits and the fan comes on reguardless of whether its on or off at the console and also dosent matter wether the key is on or off.
Had this problem before the fan quit working, any ideas ?
Old Nov 30, 2005 | 04:37 PM
subford's Avatar
subford
will any reader work ??
You do not even need a reader, just use a test light.
This makes it sound like I gave you the wrong print, it sounds like your circuit has a relay in it. Replace the bad Blower Motor Relay (LH side of engine compartment).
Old Jan 24, 2006 | 09:53 AM
SonnyD's Avatar
SonnyD
Any idea the part # ?
Called two ford dealerships and they both said that there isnt a blower motor relay
Old Jan 24, 2006 | 07:10 PM
skier-24's Avatar
skier-24
1990 E150 has a relay. It is located in front of the battery above the headlight plug.
Old Jan 26, 2006 | 02:43 AM
Dannym's Avatar
Dannym
I have an '87 E150 and had a LOT of problems with the fuse for the blower motor. It's the only fuse that causes trouble but it's the highest current fuse in there. It won't blow visibly but seems to want to break inside the metal cap, then it kinda comes and goes or just stops working. I believe I even read the fuse was a good connection when I put an ohmmeter on it but then read 12v from one side of the fuse to the other when the blower was turned on. Spent awhile figuring that out. I think it happened on 2 different fuses too.
Old Jan 26, 2006 | 05:44 AM
rebocardo's Avatar
rebocardo
As long as there is not an an electrical fault, what you need is a slow blow fuse. If it still blows, there is a bigger problem then the fuse. At the worse, you can always put a circuit breaker in.
Old Jan 26, 2006 | 05:06 PM
Dannym's Avatar
Dannym
It was a slow blow fuse.
I think it was a problem with the fuse holder, it was heating up enough that it cooked the connection of the fusible element to the metal cup at the end. When I took the fuse out and examined it more carefully this was the area where the fuse malfunctioned.
If I was going to replace it (and I might), I'd definitely splice in a blade-type fuse holder. They sell well-made holders with pigtails for just this. I HATE these old glass ones.
Nicmike
Nov 26, 2019 09:46 PM
Tominky
2009 - 2014 F150
Jun 10, 2017 03:51 PM
Usaman
Nov 10, 2016 09:31 AM
LeeTribeRide
Nov 9, 2013 04:10 PM
2002sport
Escape & Escape Hybrid
Oct 23, 2010 11:01 AM
